Oscillating inlet BC
Old   March 21, 2012, 02:25
Default Oscillating inlet BC
November is on a distinguished road
Hello all,
I am trying to set up a 3D case for an oscillatory flow past a circular cylinder. I'm wondering how would you specify the inlet and outlet BC for this easy case? It got me stuck here...
For the inlet boundary condition, I want to have Ui=Um*sin(2*pi*frequency*t), so i have set "patch" in /constant/boundary file for the inlet (for the top and bottom boundaries, which are perpendicular to the cylinder span, i have set "cyclic" BC for infinite length cylinder), and in /0/u file i have :
inlet
type oscillatingFixedValue;
refValue (0 0 0);
amplitude 1;
frequency 0.5;
For 0/p:
inlet
type calculated;
value uniform 0;
But when I run it, the following error msg appears:
--> FOAM FATAL ERROR:
gradientInternalCoeffs cannot be called for a calculatedFvPatchField
on patch inlet of field p in file "/home/kyang/OpenFOAM/OpenFOAM-2.1.0/icoFoam-t/3DCylinder/0/p"
You are probably trying to solve for a field with a default boundary condition.
From function calculatedFvPatchField<Type>::gradientInternalCoef fs() const
in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 186.
FOAM exiting
Seems like it is complaining that I didnt define p, but as I said, I did subscribe inlet BC for p in 0 folder!
I'm just wondering if any one has any ideas on what's the problem for this... or any suggestions on the setup for BC and initial condition for oscillatory flow past a circular cylinder would also be great!
Thanks a lot!
November is offline   Reply With Quote
Old   March 21, 2012, 05:11
Olivier
olivierG is on a distinguished road
hello,
Why have you set to "cyclic" your boundary ?
oscillatingFixedValue work with patch type.
And for pressure, use outletInlet or zerogradient.
regards,
olivier
olivierG is offline   Reply With Quote
Old   March 21, 2012, 08:28
calim_cfd's Avatar
mauricio
calim_cfd is on a distinguished road
hi,
in the boundary fle you can have primitive BCS : cyclic(AMI),symmetryPlane, patch, wall
inlets and outlets are type "patch" in the boudary file
in the variable files you may set specific stuff like the one you did:
when you use cyclic or symmetry you can only assign these types of bc in the variable files.
but the primitive bcs in the boundary file gotta be "patch"
check the user guide.. it has more to it
Best Regards
/calim
"Elune will grant us the strength"
calim_cfd is offline   Reply With Quote
Old   March 21, 2012, 20:27
Hi guys,
First really thank you for your reply!
Second sorry it was a typo,,, I didn't use cyclic in inlet and outlet, I did use patch, I have changed that typo in my post... sorry about the confusing...
then, my problem is, how would you specify the condition for initial p in 0/p after setting 0/u at inlet to be oscillatingfixedvalue? According to NS, once you have u=Um*sin(2*pi*f*t) then at inlet you ought to have partial(p)/partial(x)=-partial(u)/partial(t)=-Um*2*pi*f*cos(2*pi*f*t). Basically p should be calculated according to u... therefore I have set 0/p to be calculated at first, but then the error like I described in my post appeared...
And I tried to use zeroGradient, however i got all values of p and u at all timesteps to be 0 following that specification. Here's what I did:
In my input file for boundary:
inlet type is set to be patch
and then in 0/p,
inlet type is set to be zeroGradient;
in 0/u, if i want to specify U=Um*sin(2*pi*f*t),would the following be correct?
inlet
refValue uniform (0 0 0); //steady current velocity, which is 0 in my case
//offset (0 -1 0);
amplitude constant 1; //Um
frequency constant 0.5; //f
//value uniform (0 0 0); //not sure what this is for?
Could you tell me my problem, really appreciated.
Old   March 21, 2012, 20:46
Hello Oliver,
Thank you for your suggestion.
I tried outletInlet for 0/p at inlet as following:
inlet
type outletInlet;
outletValue 0;
value 0;
And I still got all 0 values for p and u at all timesteps....
I begin to wonder if I should specify inletOutlet at outlet for U and p too? In my current settings I just used zeroGradient for u at outlet and p=0 at outlet. This looks less scientific now... should I change it to inletOutlet then?
boundary condition, cylinder, oscillatingfixedvalue, oscillatory flow
higher total pressure at inlet motorbean Main CFD Forum 0 December 7, 2011 16:13
Inlet Velocity in CFX aeroman CFX 12 August 6, 2009 18:42
Inlet shapes for modelling a fan in an inlet duct buzzybee CFX 10 June 11, 2009 20:15
Oscillating inlet??? Adam CFX 0 March 10, 2008 20:57
Diffusion component at inlet Balaji FLUENT 2 August 8, 2005 07:37
