[swak4Foam] Installation of swak4foam problem
Like Tree1Likes
  • 1 Post By philippose
Old   March 19, 2012, 03:11
Default Installation of swak4foam problem
Anone
CFD_user_2012 is on a distinguished road
Hi all
I downloaded swak4foam files. I typed in
./Allwmake
Then the files are installed into the
platforms/linux64GccDPopt/lib/libgroovyBC...
etc...
However it does not seem to installed when I go to Openfoam and find that it does not recognise the groovyBC command
I am not sure if it installed properly
Please help
CFD_user
CFD_user_2012 is offline   Reply With Quote
Old   March 19, 2012, 09:35
Assistant Moderator
Bernhard Gschaider
Originally Posted by CFD_user_2012 View Post
Hi all
./Allwmake
etc...
Please help
CFD_user
groovyBC is not a command. It is "only" a boundary condition. Have a look how to use that via the libs-entry in the controlDict
One command/utility that swak4Foam installs funkySetFields. If that executes then chances are good that swak installed correctly
Old   March 24, 2012, 17:02
Default Problem geting parts of Swak4Foam to run
Kevin Flora
kflora is on a distinguished road
I have compiled Swak4Foam on Kubunutu 11.10 with OF 2.1.x and don't see any probems with the compilation (see attached log). While I have no problems executing commands such as "funkySetBoundaryField", the python commands (e.g., pyFoamPlotRunner.py etc) are do not work and give "command not found" at the prompt. What do I need to do to have these commands recognized, or are they just not compiling right?
kflora is offline   Reply With Quote
Old   March 24, 2012, 17:22
Philippose Rajan
philippose will become famous soon enough
Hello Kevin,
A Good Afternoon to you!
I think you have misinterpreted something in the documentation regarding swak4Foam.
The command you are trying to run "pyFoamPlotRunner.py" is not a part of the swak4Foam suite. It is a part of the "PyFoam" Package which is another set of utilities completely independent and unrelated to swak4Foam.
If you are interested in PyFoam, have a look at the following link:
http://openfoamwiki.net/index.php/Contrib_PyFoam
You can also read about the Installation and Usage of PyFoam from the same Website.
Also look at the following presentation by Berhard Gschaider (main driving force behind PyFoam and swak4Foam):
http://openfoamwiki.net/images/e/e0/...UWien_2012.pdf
Hope this helps!
Have a great day ahead!
Philippose
kflora likes this.
philippose is offline   Reply With Quote
Old   March 24, 2012, 17:37
Kevin Flora
Philippose,
Thanks for you quick help. You were exactly right that I was a bit confused about what was included in swak4Foam. I've got PyFoam working now.
Old   April 7, 2012, 09:03
Martin
latvietis is on a distinguished road
Greetings!
I get this error and I couldn't find solution in forums. I guess it is rather simple error then...
Bison is version coetmeur@icdc.fr
No 'swakConfiguration'. Python etc won't work
OpenFOAM-version: Major  Minor  Patch
No change to Libraries/swak4FoamParsers/foamVersion4swak.H
./Allwmake: line 87: wmake: command not found
./Allwmake: line 93: wmake: command not found
I believe Bison is installed successfully, I don't know about Python though.
I downloaded Python-2.7.2, extracted it and then followed installation manual. So everything should be in place I guess.
Sincerely,
Martin
latvietis is offline   Reply With Quote
Old   April 7, 2012, 16:08
Retired Super Moderator
Bruno Santos
Hi Martin,
According to the error message, the problem is that you didn't have a working OpenFOAM environment, which is why "wmake" was not found!
I wrote sometime ago a blog post explaining a bit about how the "OpenFOAM environment" works: Advanced tips for working with the OpenFOAM shell environment
Best regards,
Bruno
Old   April 7, 2012, 17:02
Martin
Wow, that doesn't sound good. Could it mean I would need to reinstall OpenFOAM?
Old   April 7, 2012, 19:14
Bruno Santos
It depends:
  • Are you able to use anything else from OpenFOAM?
  • Which version of OpenFOAM did you install?
  • From the same command line where you tried to build swak4Foam, are you able to run icoFoam?
    icoFoam -help
  • Have you got only one version of OpenFOAM installed or more than one?
Old   April 8, 2012, 14:58
Martin
This seems serious. OpenFoam just doesn't work anymore. I believe this happened after I installed Python. Every time when I open console it shows
bash: /opt/openfoam210/etc/bashrc: No such file or directory
I believe I have to do clean reinstall of everything now?
Martin
Old   April 8, 2012, 15:48
Bruno Santos
Hi Martin,
What does this output:
ls -l /opt/openfoam210
If it outputs nothing, it looks like OpenFOAM got removed due to some weird dependency conflict versus python.
In theory, the only step you need for installing OpenFOAM once again is running this command:
sudo apt-get install openfoam210 paraviewopenfoam3120
Best regards,
Bruno
Old   April 9, 2012, 17:43
Assistant Moderator
Bernhard Gschaider
Martin
I doubt that Python is the problem directly. Maybe OF got "upgraded" when you were using the package manager
Before you do anything harsh have a look in /opt whether OF has moved to a similarly named directory
Old   April 11, 2012, 05:30
Martin
Well, yeah. It outputs nothing. I have paraviewopenfoam3120 folder in there. But I actually just checked that paraview is also removed.
Old   April 11, 2012, 05:34
Martin
Ok, I'll try to reinstall everything. Still, how should I properly install swak then?
I should just simply write in console:
and then in download folder run ./Allwmake
right?
Edit: Ok, done. It works.
[swak4Foam] swak4foam >>>> INSTALLATION PROBLEM steven123 OpenFOAM Community Contributions 35 January 11, 2021 16:53
[OpenFOAM.org] Problem in installation of OpenFOAM-2.3.x Parisa_Khiabani OpenFOAM Installation 5 December 4, 2014 09:04
RHEL 6.3 Installation problem Turbulent STAR-CCM+ 0 September 3, 2014 07:01
[swak4Foam] installation problem: "./Allwmake: ... [[: not found" Rajarshi OpenFOAM Community Contributions 8 May 13, 2013 08:05
[swak4Foam] About installation of swak4Foam mmkr825 OpenFOAM Community Contributions 10 December 14, 2012 01:24
