April 2, 2012, 10:41 |
foamToVTK -allPatches
Hi all;
I tried to run Code:
foamToVTK -allPatches The problem is that I can only get cell data, I cannot get any point data. (Don't know if these terms are correct but you can have a look at the attached image to understand what I'm saying.) Any way to have the point data with this command? Thank you! |
April 3, 2012, 10:45 |
Aurelien Thinat
In paraview, you can switch cell data to point data. I can't checked the exact name right now, but have a lokk in the "alphabetical list" (with calculator / elevation / etc... tools).
April 3, 2012, 10:50 |
Thank you for your help.
Actually I think that my problem is that those data don't get exported, is not a matter of visualizing them in paraview… |
April 3, 2012, 10:57 |
Aurelien Thinat
Yes, "foamToVTK" exports only cell data as far as I know.
April 3, 2012, 12:24 |
That's not true, if you look at the image attached you'll see what you get with foamToVTK without the flag -allPatches.
[OpenFOAM] foamToVTK and paraFoam show different results | akidess | ParaView | 2 | October 29, 2010 05:36 |
Command foamToVTK | gruber | OpenFOAM | 0 | July 26, 2010 09:44 |
foamToVTK | sameer_kumar | OpenFOAM Post-Processing | 1 | May 6, 2010 21:17 |
[Technical] How to get polyhedral mesh without additional cells when using foamToVTK | chnrdu | OpenFOAM Meshing & Mesh Conversion | 4 | June 10, 2008 13:08 |
[OpenFOAM] FoamToVTK error with OF 13 | melanie | ParaView | 1 | May 22, 2006 04:40 |
