chtmultiregionFoam - Gradient at Coupling boundary |
February 17, 2011, 08:39 |
alireza j
Rep Power: 15 |
Dear Friends,
I was wondering if it is possible to have a gradient boundary condition in the interface boundary at the same time with coupling boundary condition. I aim to have a coupling boundary between solid and fluid and at the same time it should be a heat source in the interface boundary. I checked almost all related thread and also http://www.cfd-online.com/Forums/ope...egionfoam.html which is mostly to add heat source in the solver rather than on the boundary. I was also thinking to have one side (fluid part) coupling:solidWallMixedTemperatureCoupling and the other side (solid part) fixedGradient: solidWallHeatFluxTemperature , but it didn't work. I appreciate if you help me in this issue. |
April 2, 2012, 11:50 |
mahdi abdollahzadeh
Rep Power: 15 |
today i tried to test a case with chtMultiregionFoam.
my case includes natural convection in an enclosure with a block at the bottom. the bottom surface of block was heated. the strange thing is that the temperature is not passing throgh solid zone to fluid zone. I am using turbulentTemperatureCoupledBaffleMixed as the boundary condition on the interface of soid and liquid zone. I thinck there should be sth related to boundary condition. I will be too much thankful to recive you oponions . |
CFX does not continue | Shafiul | CFX | 10 | February 17, 2011 07:57 |
External Radiation Boundary Condition (Two sided wall), Grid Interface | CFD XUE | FLUENT | 0 | July 8, 2010 06:49 |
temperature normal gradient on a boundary | Sandrine | Main CFD Forum | 2 | June 10, 2009 16:34 |
normal temperature gradient on a boundary | Sandrine | FLUENT | 0 | June 10, 2009 12:29 |
Boundary condition vector field gradient from two sides of patch face | quba | OpenFOAM | 0 | December 12, 2007 05:26 |
