DirectMapped in FSI problems
Hi, I'm trying to model a fluid structure interaction using LES. I generate the turbulence at the inlet implementing a recycling technique (similar to that of Lund et all) using directMapped BC. Now, my mesh has to be able to deform, however when I run my case I get:
Create time Create dynamic mesh for time = 0 Selecting dynamicFvMesh dynamicMotionSolverFvMesh Selecting motion solver: laplaceFaceDecomposition --> FOAM FATAL ERROR: Unknown faceTetPolyPatchFaceDecomp type directMappedPatch. Valid faceTetPolyPatchFaceDecomp types are : 7 ( wall processor wedge patch empty ggi symmetryPlane ) From function faceTetPolyPatchFaceDecomp::New(const polyPatch&, const tetPolyBoundaryMeshFaceDecomp&) in file tetPolyMeshFaceDecomp/tetPolyPatches/faceTetPolyPatch/newFaceTetPolyPatchFaceDecomp.C at line 59. FOAM exiting Does this mean that deformable meshes cannot be used with DirectMapped Bc's? Do I have to set three different domains and link them together? (one recycling domain, one fluid domain with deformable mesh and one solid domain) I will appreciate any help or suggestions. Thanks |
Unfortunately, I cannot help but I can report a similar error message. I'm attempting to use the regionCouple boundary in OpenFOAM-1.5-dev which throws the same error that you reported. If anyone has an idea of what we're doing incorrectly, I would certainly appreciate a pointer in the correct direction. I've been pouring over the source files to try and gain a better understanding, but I'm still stuck. Regards |
