April 14, 2012, 10:40 |
-solved- [OF1.6-ext] icoFsiFoam not present
Vieri Abolaffio
Rep Power: 16 |
Dear All.
I'm starting to perform some Fsi simulations with openfoam. after some googling i've found that icoFsiFoam might be what i need so, in order to start playing with it and not mess up with my 2.0.x machine, i've set up a Vm in virtuabox, installed ubuntu 10.04 lts and installed OF1.6-ext -dev -docs from the binaries, following the howto on the wiki http://openfoamwiki.net/index.php/In...ucid_10.04_LTS all went good and well. everything is working fine, meaning that who took kare of making such a complex sw available as a distributuion did a fantastic job. unfortunately i cannot find the fsi solver. from what i've read in the forum: http://www.cfd-online.com/Forums/ope...-not-work.html http://www.cfd-online.com/Forums/ope...-problems.html it is ported to the 1.6-ext (page 3 of the second link, now working in parallel) and tutorials for it should be found in /usr/shared/doc/openfoam-1.6-ext/examples/stressAnalysis but it isn't here. any suggestions or ideas to help me get it up and running will be welcome. Last edited by sail; April 14, 2012 at 10:58. |
April 14, 2012, 10:58 |
Vieri Abolaffio
Rep Power: 16 |
nevermind, i found a testcase here http://www.cfd-online.com/Forums/ope...cofsifoam.html and managed to test the installation. it actually works.
thanks again. Ps, if anybody have others case files, i'd be glad to take a look at them. |
April 16, 2012, 11:32 |
Benchmark for Fluid-Structure Interaction solver (IcoFsiFoam) | Eferal | OpenFOAM | 3 | October 3, 2013 03:04 |
icoFsiFoam in OF1.6-ext does not work | mechy | OpenFOAM | 4 | July 26, 2011 03:14 |
icoFsiFoam case needed | vivekcfd | OpenFOAM | 1 | May 6, 2009 13:41 |
IcofsiFoam not supported under released 141 package | pi06jl6 | OpenFOAM Running, Solving & CFD | 4 | June 26, 2008 13:59 |
Errors in running a icoFsiFoam case | jin_xu | OpenFOAM Pre-Processing | 0 | June 9, 2008 06:48 |
