How would you like openFoam to be?
I know many companies/private users have "their own openFoam version" that was customized for their need…
So, I would like us to share our ideas about how would you like openFoam to be. In my mind, for instance, I would really appreciate not having to set the boundary conditions in many different files (U, P, K, nu…) but to have, instead, one single file in which to the every boundary condition at once. And you? |
its easy you can use, changeDictionary option in OpenFOAM, then you can put all your boundary in One file look at chtMultiRegionFoam tutorials
My wishlist:
1) Relevant equations in solvers include sources as fields; I mean, e.g., in the example of icoFoam with temperature http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam , the temperature equation could include a heat source: fvScalarMatrix TEqn ( fvm::ddt(T) + fvm::div(phi, T) - fvm::laplacian(DT, T) + Q // heat source ); 2) A small convenience (IMHO): separate input and output data. Currently, the case folder has the following subfolders before running a solver: 0 constant system After running the solver, this folder looks like this: 0 0.001 0.002 ... (zillion subfolders for time steps) ... 10 constant system These intermediate time steps could be put into a separate subfolder, like this: 0 constant output/0.001 output/0.002 ... system |
