topoSetDict
Like Tree2Likes
  • 2 Post By latvietis
Old   April 11, 2012, 06:49
Default topoSetDict
Samuele Z
samiam1000 is on a distinguished road
Dear All,
I am working with topoSet. I have a cellZone file (generated with the fluent3DMeshToFoam) and I have this topoSetDict file:
|  \\    /   O peration     | Version:  dev                                   |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      topoSetDict;
actions
        name    door_and_roof;
        type    cellZoneSet;
        action  new;
        source  zoneToCell;
        sourceInfo
            set door;           // name of cellSet
        name    door_and_roof;
        type    cellZoneSet;
        action  add;
        source  zoneToCell;
        sourceInfo
            set roof;           // name of cellSet
        name    internal_air;
        type    cellZoneSet;
        action  new;
        source  zoneToCell;
        sourceInfo
            set internal_air;           // name of cellSet
        name    external_air;
        type    cellZoneSet;
        action  new;
        source  zoneToCell;
        sourceInfo
            set external_air;           // name of cellSet
        name    external_air;
        type    cellZoneSet;
        action  add;
        source  zoneToCell;
        sourceInfo
            set infinite_air;           // name of cellSet
When I try to give the command
topoSet
I get this error:
lab@lab-laptop:~/Documenti/cases_OF/OF_case11_test$ topoSet
|  \\    /   O peration     | Version:  2.1.0                                 |
Build  : 2.1.0-0bc225064152
Exec   : topoSet
Date   : Apr 11 2012
Time   : 12:43:34
Host   : "lab-laptop"
PID    : 6253
Case   : /home/lab/Documenti/cases_OF/OF_case11_test
nProcs : 1
Create time
Create polyMesh for time = 0
Reading topoSetDict
Time = 0
    mesh not changed.
Created set door_and_roof
    Applying source zoneToCell
--> FOAM FATAL IO ERROR:
keyword name is undefined in dictionary "/home/lab/Documenti/cases_OF/OF_case11_test/system/topoSetDict::actions::sourceInfo"
file: /home/lab/Documenti/cases_OF/OF_case11_test/system/topoSetDict::actions::sourceInfo from line 27 to line 27.
    From function dictionary::lookupEntry(const word&, bool, bool) const
    in file db/dictionary/dictionary.C at line 400.
FOAM exiting
What's wrong?
Thanks for any help,
Samuele
samiam1000 is offline   Reply With Quote
Old   April 11, 2012, 07:17
Martin
latvietis is on a distinguished road
The error means it needs 'name' instead of 'set'.
Martin
wyldckat and Owais Shabbir like this.
latvietis is offline   Reply With Quote
Old   August 23, 2013, 02:55
vishal
vishal_s is on a distinguished road
Hello Samuele Z, can you kindly tell me what is the command to run the "toposet dict file"??
vishal_s is offline   Reply With Quote
Old   August 23, 2013, 08:39
sivakumar selvaraju
sivakumar is on a distinguished road
Send a message via Skype™ to sivakumar
hi just type topoSet
sivakumar is offline   Reply With Quote
Old   February 1, 2018, 07:11
Default toposet
mohan
mohan.labade is on a distinguished road
Hi Samuele
Can you find any solution? Only changing name it will work or not?. I am also having same issue.
Thanks for help
Mohan
mohan.labade is offline   Reply With Quote
Old   July 23, 2019, 11:45
Owais Shabbir
Owais Shabbir is on a distinguished road
I hope you guys have found your answer. If yes please share.
to elaborate more on what Martin said, the problem is the keyword 'set', I checked the topoSetDict file at github and it should be 'name'.
When using zoneToCell the sourceInfo entity requires not to provide set but rather name of the zone.
https://github.com/OpenFOAM/OpenFOAM...et/topoSetDict
Hope it helped anyone. If you had found an alternate solutions share as well.
If you think I am incorrect please mention it too. =)
OS
Owais Shabbir is offline   Reply With Quote
topoSetDict in simpleFOAM Goutam OpenFOAM Running, Solving & CFD 2 August 13, 2012 07:47
