Grid generation for traingular channel
Old   September 3, 2001, 05:54
Default Grid generation for traingular channel
sandip
I am using PHOENICS 3.2. How can i generate grid for traingular channel? I had tried with general menu but without four lines i cann't define a frame and hence the grid lines. Is there any traingular shape available in VR-editor??
Please help me out.
Thanks in advance.
Sandip
Old   September 6, 2001, 20:20
Default Re: Grid generation for traingular channel
leon
The way I have solved similar problems is to define the space a rectangle. Change the geometry of the shape, using the properties feaure on the object to create a wedge/triangle. Set up the tiangluar channel as the domain space inbetween the wedges.
From here refine mesh as required.
I hope this helps.
Leon
Old   October 4, 2001, 12:02
David Glynn
Alternatively, if you want to use BFCs, you can make a frame which is effectively triangular by defining two of the corner points to be the same point. In other words the triangle is represented as a quadrangle, where one of the sides has zero length. This works fine!
Creating a grid for a channel inside a brick sanin FLUENT 0 November 6, 2008 08:03
Grid Generation ambroz Main CFD Forum 1 January 11, 2007 03:16
Grid generation Z Main CFD Forum 2 February 22, 2005 04:31
Grid Generation Tim Main CFD Forum 7 July 14, 2001 02:10
collocated grid for turbulent channel flow!! frederic felten Main CFD Forum 0 July 11, 2000 22:01
