Nusselt number
Old   March 12, 2002, 01:56
Default Nusselt number
H.C.
Could you pl. suggest how can one get the Nusselt number by running PHOENICS.
Old   March 20, 2002, 12:05
Default Re: Nusselt number
Dr. Peter Bailey
Please see the CHAM website at... http://www.cham.co.uk
Then pick the SEARCH facility, and look for Nusselt.
There are a number of references to the Nusselt number which will be turned up by the search.
You can use the very powerful PLANT , or In-Form systems in PHOENICS to set a variable of a chosen name, say NU for the NUSSELT number = to the required expression, as a function of other variables calculated and stored by PHOENICS.
For a scalar, your variable,e.g.the Nusselt number, is then calculated and stored by Phoenics for all relevant cells, and then, using PHOENICS-VR and PHOENICS-VR, you can plot contours of Nusselt numbers and Isosurfaces.
The above search on CHAM's web-site should tell you details, or you can look via the Encyclopaedia on the web-site. Paths for 3 references from the above, that may be of particular interest are...
http://www.cham.co.uk/phoenics/d_pol...ow/iminga2.gif
http://www.cham.co.uk/phoenics/d_polis/d_lecs/plant/ vartyp.htm
http://www.cham.co.uk/phoenics/d_pol...nt/plan156.htm
Regards,
Pete (Dr. Peter Bailey).
nusselt number negar Main CFD Forum 1 August 10, 2008 14:47
nusselt number meenu FLUENT 3 October 18, 2006 23:12
Nusselt number Silke Renner FLUENT 1 July 20, 2005 08:14
Nusselt number Stex CFX 0 June 24, 2004 09:14
Nusselt number tod Phoenics 0 October 18, 2002 09:56
