April 10, 2002, 12:01 |
About the TEM1 source
I found that in the RESULT file, the source of TEM1 of air is calculated by enthalpy and the zero point is selected at 0 K. I wonder if I can change the zero point to 0 centigrade. Thank you!
April 11, 2002, 20:20 |
Re: About the TEM1 source
Ben,
My understanding is that the TEM1 term is in K, because all of the maths that use enthalpy and most other thermodynamic equamtions are based on K, not centigrade. My understanding of enthalpy roughly speaking; is that any material at 0 K, is at 0 enthalpy air or other materials at 0 C = 273 K that means that the material has some internal energy hence some enthalpy. So my answer would be that you can not change this set point. Hope this helps. Leon |
contribution of convective source in total source? | Antony | Phoenics | 4 | July 30, 2008 06:15 |
Volumetric source or Inlet source | Kumar | CFX | 0 | May 12, 2008 10:33 |
Source and Source coefficient | Ramcharan | CFX | 0 | February 13, 2008 08:27 |
UDF for 3D Source | Mel | FLUENT | 0 | March 26, 2001 12:02 |
Latent heat introduced by the TEM1 equation? | H.P.LIU | Phoenics | 1 | January 11, 2001 11:03 |
