temperature going negative behind a bluff body
Old   November 23, 2006, 06:56
Default temperature going negative behind a bluff body
Sourabh
I am trying solve a problem of high mach flow over a bluff body, when i switch on laminar code, temperature goes negative (suddenly) near wall behind the body, can anybody suggest me why it happens and any remedies or so?
Sourabh
Old   November 28, 2006, 18:34
Default Re: temperature going negative behind a bluff body
Carlos
Sourabh,
I have a converged example with high mach number that I may send to you. Please send me your e-mail address.
About the negative temperatures: are you using Celsius or Kelvin? Negative temperatures are not always a wrong answer, especially in those occasions you have larges rarefactions.
You may also be experiencing convergence problems and you might use dense meshes to get the correct phenomenum.
If you send me your q1 file, I may try to have a look.
Regards,
Carlos.
Old   November 28, 2006, 23:21
Sourabh
I think u r right, i have a problem of large rarefaction, can it be avoided by use of dense meshes or are there any other treatments?
Sourabh
Old   November 29, 2006, 05:13
Carlos
Mesh is crucial but you may have to control MAX and MIN values of density, for instance.
Carlos.
Old   November 29, 2006, 06:08
Sourabh
i reduced CFL no. that helped the rarefaction i think , thank you.
Old   November 7, 2007, 02:49
Default Re: temperature going negative behind a bluff body *NM*
nahid
Old   December 1, 2007, 18:50
patti
You can set minimum allowed temperature(s) in MENU/Numerics/Limits on variables Patti
flow behind bluff body puneshwar verma FLUENT 0 February 27, 2007 06:12
Bluff Body krithiga Siemens 4 November 7, 2006 15:45
bluff body and Y+ justin FLUENT 3 May 4, 2006 20:13
RSM+bluff body anto FLUENT 2 March 1, 2006 09:39
BLUFF BODY+ RSM Anto FLUENT 2 August 3, 2005 05:09
