3d array.....
Old   July 2, 2009, 06:18
Unhappy 3d array.....
amit kumar barik
fastnfuriousamit is on a distinguished road
Hello friends,
Well I use PHOENICS 3.5.1 and am currently trying to do a current distribution problem in 3 dimensions.
I need to give the boundary conditions in 3-d patches.
While doing the same problem in 2-d i gave the following ground coding.
"DO IY=1,IG(2)
DO IX=NX,NX
F(INDYX(VAL))=23.008
ENDDO
ENDDO"
But how do i declare a 3-d array??
I need to know what functions should i use instead of F(INDYX)???
fastnfuriousamit is offline   Reply With Quote
Old   August 13, 2009, 12:24
John Ludwig
John_L is on a distinguished road
The patches are always visited 'per Z plane', and only on planes where the patch exists. You do not need to declare 3D arrays or change your code, though something like:
l0val=l0f(val)
do ix=ixf,ixl
do iy=iyf,iyl
i=(ix-1)*ny+iy
f(l0val+i)=23
enddo
enddo
would be a more normal way of doing it. ixf,ixl,iyf,oyl are set internally to the limts of the current patch so you don't need to set them yourself.
John_L is offline   Reply With Quote
Geometry array in Gambit CUser FLUENT 0 November 1, 2008 10:50
ARRAY PASSING in STAR4 John Siemens 2 September 22, 2008 14:39
How to convert cgns file in node array? John Siemens 0 November 12, 2006 22:55
How to convert cgns filr in node array? John FLUENT 0 November 12, 2006 22:54
How to conevrt cgns file in node array for metis? John CFX 0 November 12, 2006 22:54
