Home > Forums > Mesh Generation & Pre-Processing Software > Pointwise & Gridgen
Connection B.C. Problem
Like Tree5Likes
  • 1 Post By taxalian
  • 2 Post By cnsidero
  • 2 Post By dgarlisch
Old   October 5, 2013, 06:36
Default Connection B.C. Problem
paraglider is on a distinguished road
Hi everyone
When I create 2 neighbour domain by meshes (in 2D), I everytime have a problem while loading it to FLUENT. It says "No face with given nodes". I searched and found it's about the "connection" in Boundary condition.
If you look at the picture in the attachment named "pic-1" you will see there is 2 mesh domain and a connection between them. I think this connection makes the problem.
Even if I made Pointwise 2D T-Rex mesging "Tutorial", I can load it to FLUENT but I can't even initialize it. It doesn't moves. There is a connector too. (as seen in the attachment "Mesh-2"). Pointwise or Fluent can not connect theese meshes.
What should I do with theese connections?
Thank you...
paraglider is offline   Reply With Quote
Old   October 6, 2013, 16:49
taxalian is on a distinguished road
Send a message via Skype™ to taxalian
I tried the similar tutorial as you mentioned, it didn't work in 2D. But if you choose the 3D mode and use a kine of 2D grid with one cell thickness for your finite volume in third dimension then it works fine with Fluent.
In Gridgen , the 2D meshes export for Fluent works by using the block command for both the structured and unstructured meshes i.e making separate block for different mesh shapes. Don't forget to have the similar orientation for structured meshes if you have more than one block.
If you have Gridgen then you should not get such problem as faced now in Pointwise. It seems to be a bug or we don't know the right option.
paraglider likes this.
taxalian is offline   Reply With Quote
Old   October 6, 2013, 17:20
Chris Sideroff
cnsidero is on a distinguished road
Originally Posted by paraglider View Post
Hi everyone
Thank you...
2 things you should check:
- domain orientations need to point in the +z direction
- domains in a single volume condition
-Chris
taxalian and paraglider like this.
cnsidero is offline   Reply With Quote
Old   October 7, 2013, 09:36
Thank you all. I made the tutorial again. In "assemble domain", I selected nodes "counterclockwise" (not in clockwise as tutorial says for CGNS solver), then it's oriantation gets in +z direction. And fluent solved it.
I have one more question. I can join 2 neighbour unstructured domain. Is it what you said "domains in a single volume condition" Chris? What can I do with structured and unstructured neighbour domains?
I can't make them complete 1 domain.
Thank You...
Old   October 7, 2013, 10:27
Hi Chris,
thanks a lot for this useful tip and i assume by single volume condition you mean single fluid volume boundary condition consists of several domains.
Old   October 7, 2013, 13:09
David Garlisch
Location: Fidelity Pointwise, Cadence Design Systems (Fort Worth, Texas Office)
dgarlisch is on a distinguished road
Originally Posted by taxalian View Post
Hi Chris,
I believe Chris' answer would be yes.
In 2D grids, the Pointwise domains entities are the "volumes".
You can assign Volume conditions to the domains using the CAE/Set Volume Conditions... menu.
Fluent does NOT like connected volumes with differing VCs. It will make interesting changes to the grid conditions during import if it detects this.
So, you have at least three options:
  1. Leave all VCs set to Unspecified (the default for all newly created 2D domains).
  2. Create a single VC (of any type) and assign it to all 2D domain volumes.
  3. Use different VCs and deal with the changes made by Fluent during import.
dgarlisch is offline   Reply With Quote
Old   October 7, 2013, 14:46
Hi David,
Thanks for your reply and useful hints.
Old   October 8, 2013, 10:12
Thank you very much taxalian, cnsidero and dgarlisch!
I corrected meshes orientation, than I connected all the mesh volumes in new VC. fluid so the problem solved!
connections, fluent 2d, pointwise
[OpenFOAM] Paraview 3.98 - errors when saving geometry file pajot ParaView 1 September 28, 2013 10:45
Radial Turbine Analysis B.C Problem yjs1027 FLUENT 0 April 18, 2013 03:06
Interior B.C. Problem Samaneh Zeighami FLUENT 6 September 8, 2012 05:06
[Commercial meshers] Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 maverick OpenFOAM Meshing & Mesh Conversion 2 June 18, 2011 04:36
problem in giving b.c kiran FLUENT 0 August 10, 2004 04:21
