July 16, 2010, 23:37 |
Gridgen Layer Problem
Haris Hameed
I have the following geometry
I am using Gridgen V 15.10, below is the Unstructured mesh… I know that it can be structured mesh but my requirement is unstructured (the above grid is not my case and I am only using the above to explain the problem) After running the unstructured solver for the above I get The layers at the top and bottom surface converge (as shown in the above figure) Now I have tried different techniques By changing Collusion buffer aniso-iso blend values Redistributing connectors making them close to the edge Forming layers in the top and bottom domain But got no success Kindly help me in this matter |
July 17, 2010, 11:03 |
Make layers in domains to
Rick Matus
You just need to run the T-Rex (anisotropic) solver on the top and bottom domains with the same spacing and growth that you will use in the block.
In the existing grid, there is an inconsistency in the grid spacing on the boundary domains and the volume grid. Try running the DLR-F6 tutorial in Gridgen to see how this works. In that example, the symmetry domain is run with anisotropic layers to match the volume grid, just as you want to do here. If you need help, let me know. |
July 17, 2010, 13:01 |
Haris Hameed
I have tried this option but it gives the same result ....
may be i am doing something wrong but can you please elaborate about the "grid spacing on the boundary domain and volume grid" i have run the solver on the top and bottom domains with same spacing n GR as for the block but still getting same results kindly tell where i am wrong |
July 17, 2010, 15:57 |
Use symmetry on domains on side of growth layers
Rick Matus
Sorry, I gave an incomplete answer before. There are two main considerations.
First, the domains (surface grids) at the top and bottom of your picture need to have anisotropic triangles on them, so they are compatible with the anisotropic tetrahedra growing in the volume. You can do this in the Domain, Solver, Unstructured menu by setting the anisotropic layers, initial step size, and growth rate to be the same as you are using in the volume. Second, in the Block, Solver, Unstructured menu set the top and bottom domains to a Symmetry boundary condition. That will let Gridgen know to have the adjacent tetrahedral layers grow along them and include their points in the anisotropic layers. Gridgen's DLR-F6 tutorial has a good explanation of this set-up, so you might want to take a look at it. I hope I am understanding your problem correctly. If this does not help, let me know and we will try something else. Last edited by rmatus; July 19, 2010 at 10:04. |
July 18, 2010, 00:09 |
Haris Hameed
Thankx Alot the symmetry boundary cond works perfect
[GAMBIT] 3D Boundary Layer problem | Harald D | ANSYS Meshing & Geometry | 0 | April 16, 2009 04:54 |
Problem with Gridgen | chris | Pointwise & Gridgen | 5 | July 7, 2006 07:00 |
Unsteady Boundary Layer Problem | C.J.Yoon | Main CFD Forum | 0 | January 27, 2006 04:19 |
question on bounday layer modeling | Wen Long | Main CFD Forum | 2 | November 12, 2005 17:29 |
GAMBIT meshing problem | Gauthier Lambert | Main CFD Forum | 1 | August 3, 2000 09:22 |
