How to set a constant temperature for entire volume Not only its surfaces |
April 16, 2012, 06:52 |
Rep Power: 14 |
I want to have a flow(with a constant temperature) over a surface for simulating a convection simulation.
I don't want to use the Convection boundary condition because i have to set constant temperature to my surface as well. Also if i create a block around my surface as Air,I just can set the constant temperature of the air for its outer surfaces and not for the air over the surface or entire volume. Do you have any idea or suggestion regarding this? Thank you in advance. Last edited by fshak92; April 16, 2012 at 08:25. |
April 17, 2012, 11:12 |
Rep Power: 14 |
I used the 'velocity inlet' with low velocity (like 0.01m/s) to have a constant temperature for entire volume but the results are influenced by the direction of the velocity and it cannot simulate a real room with no velocity.
Do you have any idea for simulating the situation of a room with no velocity? Many thanks in advance Last edited by fshak92; April 17, 2012 at 12:41. |
April 18, 2012, 05:46 |
siamak rahimi ardkapan
Rep Power: 17 |
You need to define the system as isothermal.
April 18, 2012, 08:53 |
Rep Power: 14 |
Thank you for your reply.
But if i consider 'isothermal' then no energy equation is solved. I have a heated body(as can be seen in the above picture) in the room(block) and i want to find the Heat Transfer Coefficient. The surface of the body has the constant temperature but the air around the body can be warmed. I need to simulate a real room around my body(with constant temperature) to find the heat transfer and consequently HTC. I can set some constant temperature to block's wall but then some unwanted parameters like the dimensions influence on the gradiant of temperature and.... Do you have any idea? Many thanks in advance. |
April 18, 2012, 12:50 |
Rep Power: 17 |
Dear Omid, I think it is wise to extend the territory. and see what will happen.
I think the reversed flow problem will be solved. Is it possible to change the boundary ( the boundaries parallel to the flow)? |
April 18, 2012, 13:14 |
#6 | |
Rep Power: 14 |
I have just a body with a constant temperature in a room with a certain temperature and i want to find the heat transfer between air and my body. yes i just want to have a simple room.(the picture above) But the problem is that there isn't any velocity in my simple room. I dont know how i can consider the natural convection... (as i told above,setting some constant temperature to the walls,include some unwanted parameters(like the dimension of the block) in my simulation ) Thanks again for your answers. |
April 25, 2012, 14:29 |
#7 | |
Lucky
Rep Power: 65 |
I recommend using the segregated energy solver. If you are using the segregated solver, you can use either the temperature, isothermal, or enthalpy based formulation. But temperature is recommended. For coupled solver there is no separate treatment so no options. You will not be able to use constant density formulation. You will need to use Ideal Gas model or better (so that density can vary). Make sure you include gravity or body forces in the simulation and then start running! That's it! |
April 28, 2012, 07:21 |
Rep Power: 21 |
As soon as there is a heat transfer, you will NEVER have the same temperature all over the domain. So decide what you want! Either a constant temperature, or a solved energy equation. But you can NEVER have both of it!
You can put the walls of your room to a fixed temperature to model the big thermal mass of the walls, that would be realistic. But around a heated body, you will always have at least a thin layer with a higher temperature. That's what happens in the real world as well! |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Assigning constant temperature to an interface boundary in a conjugate HT. | fshak92 | STAR-CCM+ | 3 | February 16, 2012 07:36 |
set wall temperature | Reunion | STAR-CCM+ | 7 | January 29, 2012 06:25 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
