May 1, 2012, 19:18 |
Turbulent viscosity limited?
Breivik
Rep Power: 14 |
I am modeleing a full skale ship in ccm+ and have done som 20000 iterations, but now in the later iterations i get the message: Turbulent viscosity limited in __ cells in region Region 1. Does anyone know why this occurs? If i stop the solver it also stands that the solution is in an inconsistant state. And I'm also exsperiencing som fluctuating values of the drag coefficient. Any respons would be much obliged |
May 2, 2012, 08:24 |
Ryan Coe
Rep Power: 15 |
This is a limit that you can set. If your simulation is of a particularly high Reynolds number, it may be necessary to increase the limit. There's some info on this in the help manual.
Ryan |
May 2, 2012, 10:44 |
Breivik
Rep Power: 14 |
Ok
So it's under solver - K-Epsilon Turbulent Viscosity - Maximum Ratio? The Reynolds number is 727361600 thank you for your answer. |
May 2, 2012, 13:52 |
Lucky
Rep Power: 65 |
I do not recommend increasing the limit for the viscosity ratio. The default limit is already exceedingly high and difficult to exceed for practical flows. Increasing the tolerance on this limit will increase the likelihood of a runaway (divergence) simulation. So we already know that viscosity ratio cannot be higher than this, why let it?
May 2, 2012, 14:44 |
Rep Power: 21 |
Regarding the inconsistent state after stopping: This is just because you've stopped in the middle of a time step. So when you would postprocess in this state, the result depends on the number of inner iterations after starting the current time step. That's the inconsistency.
To get around this, just hit the "step" button. It will run again for the remaining number of inner iterations and then stop after the current time step. Oscillations of drag coefficients is nothing unusual. Although many people worry about that, it's mostly nothing to worry about. Quite often that's just due to vortex shedding. When it oscillates around a constant value and the amplitude is not too high, don't worry. Average your drag coefficient and you're fine.
We do three types of jobs here: GOOD, FAST AND CHEAP You may choose any two! |
May 2, 2012, 15:26 |
Breivik
Rep Power: 14 |
Thank you very much guys!
I let the simulation go for another 2000 iterations and it seems to oscillate around a fixed value. Best regards Breivik |
July 15, 2013, 10:19 |
#7 | |
Rep Power: 13 |
what about the situation of a moderate Reynolds number 2.3E5? |
reversed flow at pressure inlet and turbulent viscosity is limited.... | cfdiscool | FLUENT | 10 | June 10, 2015 06:15 |
Too low temperature at combustor outlet | romekr | FLUENT | 2 | February 6, 2012 10:02 |
Turbulent viscosity limited to viscosity... | Cyril | FLUENT | 16 | October 4, 2007 06:12 |
Turbulent viscosity limited to viscosity ratio... | Cyril | FLUENT | 8 | February 7, 2006 20:34 |
Problem of Turbulent Viscosity Ratio Limited | David Yang | FLUENT | 3 | June 3, 2002 06:13 |
