May 3, 2012, 05:29 |
Connect to server
Rep Power: 13 |
Hello Star-CCM+ Users,
I am trying to connect to a ccm+ server that is running on a linux machine from a Win7 computer. On the Win7 machine ssh is working without entering a password (public-private key pair), but it is still not possible to connect to the server. When I try to scan the host for running servers I get the error that no servers could be found. Connecting via ssh-tunnel is also not possible due to time out. Had anyone the same problems and has a solution for me? Thanks! |
May 3, 2012, 09:36 |
Ryan Coe
Rep Power: 15 |
I haven't been successful with the connect to server function across ssh (i think my network won't allow ssh without a password), but you might need to specify the port number on the remote server (see page below).
https://wiki.anl.gov/tracc/Speeding_..._Remote_Server Let me know how it goes.
Ryan Last edited by ryancoe; May 3, 2012 at 09:37. Reason: needed to add something |
May 3, 2012, 10:49 |
Rep Power: 13 |
Specifying a port number different from the default doesn't work. Maybe the feature "connect to server" is not really a feature but a bug...
May 3, 2012, 13:31 |
Pauli
Rep Power: 17 |
On my system, the connect to server tunneling option quit working after version 6.02. I've had a problem with 6.04 & now 7.02.
Connect to server works fine when you do not need the tunneling option. |
May 3, 2012, 13:46 |
Rep Power: 21 |
You need to log in to the machine without the need for a password. Otherwise you can't connect to the server.
The issue is, when you need the ssh tunnel option, you will not be able to connect to the Linux machine without a password. Therefore this combination will not work. An option to get around this would be to set up a vnc server on the Linux machine and forward your display to the vnc server and start a vnc client on the windows machine. LaGurk, the port number needs to meet the server port number. Any other can never work since the server will not listen to an attempt to connect on any port other than the one used when starting the server (see the output, there should be something like "server start machineName:47827" where 47827 is the port number. This number will change when more than one server is running on the same machine.
We do three types of jobs here: GOOD, FAST AND CHEAP You may choose any two! |
May 3, 2012, 13:55 |
Pauli
Rep Power: 17 |
I can login without a password. Tunneling works from the shell command line. And the same system worked fine in v6.02 but not since.
May 3, 2012, 15:10 |
Pauli
Rep Power: 17 |
Sorry. Tunneling in v7.02.008 does work. You need the correct ssh options:
"-n -o StrictHostKeyChecking=yes -o PasswordAuthentication=no -N" |
May 4, 2012, 06:23 |
Rep Power: 13 |
I don't really need the ssh tunnel option, because my server is running on the machine I can directly login from outside the company network. But scanning the host does not give any running server.
Pauli, I already tryed your options, but without any effort. I open a ssh connection from my Win7 machine using pageant, so I do not have to enter any password, to the linux machine where the ccm+ server is running. Then I start ccm+ on my local Win7 computer and try to connect to the server on the linux machine, which does not work. I even can't open a remote server on the linux machine from my local Win7 computer. Has anyone an idea, what I am doing wrong? |
May 6, 2012, 08:39 |
#9 |
Rep Power: 21 |
Do you use the same user name (login name) on the machine running the server and the machine dedicated to be your client? If not, you will not be able to connect as long as you haven't activated "collaboration" (or used the -collab switch) on the server.
Do you use the same ccm+ version? It should work within the same main version, so you should be able to connect to a 6.04.008 server with a 6.04.011 client or vice versa, but not to a 6.04.x server from a 6.0x.xx client except 6.04.x. Scanning hosts often does not work. Sometimes it helps to scan twice or even more often. But usually I need to remember the server port name and enter it in the "connect to server" dialog manually. Did you already try this?
CFD Online Back on Main Server | pete | Site News & Announcements | 0 | March 31, 2011 18:14 |
CFD Online Running on Backup Server | pete | Site News & Announcements | 0 | March 25, 2011 14:51 |
connect failed with errno%3d113 | wedsall | OpenFOAM Running, Solving & CFD | 2 | November 3, 2008 04:17 |
CFD Online Running on a New Server | CFD Online Team | Main CFD Forum | 2 | November 30, 2007 16:58 |
CFD Online Server Load | Jonas Larsson | Main CFD Forum | 0 | March 13, 2001 14:29 |
