Propeller disc theory in Star CCM+
Hey guys,
I am currently doing my master thesis in rotor aerodynamics for a small scaled helicopter. The first step before I include the main rotors in my mesh is to make a simplified verison of the model. My idea is to create a infinite thin disc over my helicopter body to simulate the flow of the rotor blade. The model will be simulated in a box which acts as a windtunnel (with a certain freestream velocity). Is there a easy way to model a disc in Star CCM+? I was wondering about this due to the fact that adding the disc will create a discontinuity in velocity and pressure around the rotor. Great forum btw //Christian |
I'm not too sure about an infinite thin disk. Maybe it works with a fan interface, but I haven't tried that.
Another option would be to create a disk with a finite thickness. Create a region from that and put a momentum source. That should work for sure (we did something similar for wind park simulations to simplify the turbines). |
I've used the finite thickness method described by abdul099 to model marine propellers. You can use a field function to set the strength of the momentum source based on some known propeller curve (ie advance ratio vs thrust and torque output).
5 Attachment(s)
I am new to CCM+ and have some problems implementing an actuator disc to simulate a propellor/wind turbine. Need some help here please as i have spent very long hours but not getting anywhere.
I have seen many of the given tutorials and I thought the following tutorials are relevant to what I wanna achieve. Quote:
My situation ahead Quote:
your guidance and help in part or whole is really really appreciated and would really make this whole work more enjoyable. thanks! |
1 Attachment(s)
In my mind, to create an Actuator Disc simulation in a wind tunnel, the aim is to create 2 regions:
a) Rotating Region (representing the Disc) b) Fluid Region (representing the wind coming onto the Disc) Quote:
Trimmer cannot currently accommodate multiple regions in one continuum. I really do not understand why. |
2 Attachment(s)
Ok so I made a bit of progress after much fiddling around over and over.
Moving ahead, I have now specified a porous region for the disc. Under porosity option, there were a few options of inputing porosity: Constant, Field Function etc... I tried an extreme case of porosity 0 as a constant value. So I expected the flow to just pass through my disc as if it was non-existent. But this did not happen and there was absolutely no change in my thrust coefficient. How should I specify a specifc thrust for my disc? Thank you! |
