Home > Forums > STAR-CCM+
Oscillating coefficient values
Old   May 4, 2012, 18:31
Default Oscillating coefficient values
Breivik
Breivik is on a distinguished road
I'm currently doing a full scale simulation of a ship with a moonpool in an implicit unsteady state and have done som 8000 iterations. The problem is that the drag coefficient value is oscillating. Is this due to the vortex sheading? And if so, what is an acceptable difference between the peak an bottom of the fluctuation? Of course given that it is oscillating around a specific value.
I'm using a time-step of 0.05s
Any answer would be much appreciated
Best regard
Breivik.
Breivik is offline   Reply With Quote
Old   May 5, 2012, 11:56
calim_cfd's Avatar
mauricio
calim_cfd is on a distinguished road
i guess that would call for some research.. guess you need some exp data.. personally, i would like to have nothing greater than 10%... but then again it all boils down to scales.. velocity..lenghtscale..and so on... hard to tell.. try digging some exp data and let us knows
gl
Best Regards
/calim
"Elune will grant us the strength"
calim_cfd is offline   Reply With Quote
Old   May 6, 2012, 09:11
abdul099 is on a distinguished road
When there's no totally weird flow behaviour, I would agree that oscillations are due to vortex shedding or other instabilities in the flow. When that's the reason, you should be able to see it in a scene. Check that and you know quickly if you're on the safe side.
How much difference you can accept is up to you. First, it depends on the order of magnitude of the average value. Second, when looking on relative values, it depends on the reference value. And there's no rule saying "oscillations up to 10% is okay, but 10.0000001% or more is completely wrong". Of course mostly it's not acceptable to have oscillations 10 000% up and down, although it's oscillating around a constant value, but there might be situations when even that is okay.
We do three types of jobs here:
GOOD, FAST AND CHEAP
You may choose any two!
abdul099 is offline   Reply With Quote
Old   May 6, 2012, 13:14
Breivik
Yes there is a big vortex inside the moonpool that i presume is a contributor to oscillating pattern.
The difference between the peak and the bottom is: 0.0044 to 0.0026
thanks for all the answers
Best regards
Breivik
Thread Tools
Trackbacks are On
Mapping values from 2D mesh to 3D mesh boundary during runtime benk OpenFOAM Programming & Development 1 June 13, 2014 02:39
problem with saving drag coefficient colopolo FLUENT 5 April 12, 2013 10:59
lid-driven cavity in matlab using BiCGStab Don456 Main CFD Forum 1 January 19, 2012 16:00
Strange values for Lift & Drag Coefficient recnice OpenFOAM Running, Solving & CFD 3 November 18, 2011 21:31
Drag Coefficient Convergence Problem John FLUENT 16 September 4, 2009 02:44
