-   STAR-CCM+ (
-   -   energy model(fluegas simulaion) in package boiler (
sjosh90 May 10, 2012 05:16
1 Attachment(s)
I have selected segregated fluid enthalpy model for energy to simulate fluegas flow inside boiler tubes. Is the selected model correct? Also explain how to specify the direction of heat flux (positive/negative) if the heat is going out of the walls of the geometry. I have attached the image of my geometry which is of fluegas path only.
abdul099 May 25, 2012 15:00
Why don't you create a simple block with just a few 100 cells and apply a positive heat flux to a boundary? Then you can see if heat is taken out of your body or put in, and you immediately know what a positive or negative heat flux means...
