surface repair
Old   May 17, 2012, 11:00
Post surface repair
David L
fisicas1 is on a distinguished road
my design is not repaired by "surface repair", we can see in the file, I try multiple ways. any advice?
thanks
fisicas1 is offline   Reply With Quote
Old   May 17, 2012, 11:25
Ryne Whitehill
rwryne is on a distinguished road
thanks
Do not worry about Close Proximity Faces & Poor Quality Faces.
Those 2 problems are solved by the surface remesher when you are meshing the part. They are only relevant on your Surface Mesh, not your Initial Surface.
rwryne is offline   Reply With Quote
Old   May 17, 2012, 11:33
David L
I believed that it did my real problem that when I have to set, meshing general cylinder I get the error "no cylinder found" in manage cylinder
Old   May 17, 2012, 11:50
Ryne Whitehill
I see you have interfacse set up. The help page for the Generalized Cylinder Mesher says you cannot have interfaces when using it. They say you can delete the interfaces, mesh the problem, and then recreate the interfaces.
All under the help page article "Working with the Generalized Cylinder Mesher"
Old   May 17, 2012, 19:25
David L
the pipe and the elbow and inside a fluid, I do not use boundary interfaces, but it is necessary to have two superfaces pipe and elbow, with this way I have cylonders. before I have the superface pipe+elbow then I should have two superfaces.
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
