how to solve the diverage of high speed centrifugal compressor, CFD code is STAR CCM |
December 10, 2011, 05:49 |
layth
Rep Power: 15 |
hello Dears,
Please could anyone help me to solve my problem with high speed turbulent flow inside centrifugal compressor. I alreadt made simulation the flow inside centrifugal compressor for specifics speeds such as 60000 rpm and 70000 and 80000 rpm ,so there is no problems and the solver converge . but when I changed the speed into 100000 rpm the solver diverage cfd code is Star CCM+ I am will be very happy if you help thanks regards |
January 2, 2012, 18:47 |
Rep Power: 21 |
Is it a stationary or transient simulation? Did you chance any parameter (like time step size or under relaxation factor) when changing the rpm? Are all other boundary conditions set appropriate to the problem with higher rpm?
May 21, 2012, 05:48 |
jk
Rep Power: 16 |
Hi Layth
I am running a compressor case in starccm+. For my unsteady analysis while the impeller makes one full rotation, my mass flow at the exit is not remaining constant and it goes on decreasing. Can You pls tell me the reason for this. Infact I have started from a steady converged case only. thanks |
jk
Rep Power: 16 |
Hi Layth
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
error in star ccm | maurizio | Siemens | 3 | October 16, 2007 05:17 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
Design Integration with CFD? | John C. Chien | Main CFD Forum | 19 | May 17, 2001 15:56 |
