May 29, 2012, 12:09 |
Water flow in a spiral like tube
IDW
Rep Power: 14 |
Hi everybody,
I'm trying to simulate a flow of water in a tube with 3 U bends. Please check the below figure. Why is the liquid flows outside the steel tube near the first U bend? |
May 30, 2012, 03:08 |
Rep Power: 21 |
Maybe a hole in your geometry? Have you checked it to be closed before meshing? Is your mesh resolution capable to catch the U-bend accordingly or could it intersect with the wrong surface when taking the interface tolerance into account?
We do three types of jobs here: GOOD, FAST AND CHEAP You may choose any two! |
May 31, 2012, 10:51 |
IDW
Rep Power: 14 |
so do you think a finer mesh size will solve the problem?
Link to sim file: https://docs.google.com/file/d/0B43E...8ya3JIdWc/edit Thank you Last edited by iDeew; May 31, 2012 at 12:25. |
May 31, 2012, 14:40 |
Rep Power: 21 |
Can't access the file. You need to set some permissions.
May 31, 2012, 15:50 |
IDW
Rep Power: 14 |
Hope you can download the file now
Thank you |
May 31, 2012, 16:17 |
Rep Power: 21 |
Got it, I'm looking on it right now.
June 13, 2012, 11:34 |
IDW
Rep Power: 14 |
Any idea on whats going on?
Thank you |
June 13, 2012, 15:38 |
Pauli
Rep Power: 17 |
Is the problem with the streamline generation? Looks like the time step is too large.
June 15, 2012, 15:32 |
#9 |
Rep Power: 21 |
Uuupps, sorry. Totally forgot to write an answer.
The issue is not the streamline generation, it's the crap model setup (sorry, I have to say that). The air box and the solid share partly the same volume and I think the interfaces are not set right. I'm sorry I don't have a picture right now. I will post it within the next one or two days. I promise!
June 18, 2012, 14:50 |
#10 |
Rep Power: 21 |
Okay, now I've got the pictures. The first two pictures are showing your setup: The air region (blue) overlays the steel region (green). Also the interfaces are not right. The water region touches the inner wall of the steel region, so far no issue. But also the air region touches the inner wall of the steel region. This is no proper setup. The air region should touch the outer wall of the steel region.
This is causing an interface between water region and the air region, causing the water to pass "through" the steel. The third pictures shows the setup how it should look like: Outer wall of the water region touches the inner wall of the steel region, the outer wall of the steel region touches the inner wall of the air region. You need to subtract the steel region from the air region and create new interfaces.
June 19, 2012, 12:17 |
#11 |
IDW
Rep Power: 14 |
I created a straight tube with interfaces.
Is this the correct way to do it? https://docs.google.com/open?id=0B43...jU1ZXBYR09HOWM Thank you for time |
problem with two phase flow (air injected in water) | miles_davis | OpenFOAM | 15 | March 31, 2021 09:36 |
3-D Water Flow in Fluent to Evaluate Pressures | ahammack | FLUENT | 2 | September 1, 2009 22:41 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 07:10 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
