-   STAR-CCM+ (http://www.cfd-online.com/Forums/star-ccm/)
-   -   Error when I add a porous region (http://www.cfd-online.com/Forums/star-ccm/102626-error-when-i-add-porous-region.html)
siara817 May 30, 2012 05:31
1 Attachment(s)
I specified some boundaries as a porous region. But when I try to run the simulation, I get an error. The error says " invalid fvregion".
Does anyone have any idea about the error?
Thanks in advance
bryan he May 31, 2012 00:58
I'm a little confusing about that "you set boundaries as porous region". Only the whole region can be difined as a porous region.
I guess you set the boundary as porous baffle, right?
If you did that, there is a restriction that the regions between this boundary should be in the same continuum, which means they should share the same "physica".
siara817 May 31, 2012 04:43
The problem was caused by the mesher. It was meshing both regions simultaneusly, so the second region was removed by the mesher. To solve the problem, I clicked the item Continua/Mesh and in the mesh properties I ticked the item per-region meshing. The problem was solved.
