May 31, 2012, 00:47 |
Multiphase + vapor extraction
I'm simulating such case: a flow is between parallel plates. A constant heat flux added on the bottom plate, while a porous media is placed above the top plate. The aim is to extract vapor generated from water (no boiling, pure evaporation) through the porous media. Does anyone know how should I select the solver for this problem? I tried multiphase segregate flow model. But it didn't work. Thank you very much! Bryan |
May 31, 2012, 04:48 |
siamak rahimi ardkapan
Can you explain more about your model selection ( which multiphase, lagrangian or eulerian?). Moreover, what was the problem that it did not work? How did you select the porous region?
May 31, 2012, 15:49 |
Sure. I use Eulerian multiphase model. You can see the detail in the picture. The problem is after only 27 steps, the troubleshooting error happens. I tried to change initial conditions more physically reasonable. But the error still happened.
The basic geometry is shown too. Upper part is porous region and lower part is fluid region. I really appreciate if somebody can give some suggestions! |
May 31, 2012, 15:50 |
Pictures for model and geometry
Please see the attachment.
Difference of multicomponent and multiphase homogenous flows | Luk_Fiz | CFX | 11 | April 4, 2013 05:29 |
Use data from multiphase into DO radiation | yashmash | FLUENT | 0 | October 7, 2011 03:57 |
multiphase multicomponent physics | ckleanth | CFX | 3 | June 4, 2009 20:15 |
Species Transport with Multiphase flow in FBR | venkat | FLUENT | 1 | July 23, 2008 23:53 |
Multiphase flow modeling | Paul | CFX | 2 | August 11, 2003 09:41 |
