Multiphase + vapor extraction
Old   May 31, 2012, 00:47
Default Multiphase + vapor extraction
bryan he is on a distinguished road
Hi all,
I'm simulating such case: a flow is between parallel plates. A constant heat flux added on the bottom plate, while a porous media is placed above the top plate. The aim is to extract vapor generated from water (no boiling, pure evaporation) through the porous media.
Does anyone know how should I select the solver for this problem? I tried multiphase segregate flow model. But it didn't work.
Thank you very much!
Bryan
bryan he is offline   Reply With Quote
Old   May 31, 2012, 04:48
siara817's Avatar
siamak rahimi ardkapan
siara817 is on a distinguished road
Can you explain more about your model selection ( which multiphase, lagrangian or eulerian?). Moreover, what was the problem that it did not work? How did you select the porous region?
siara817 is offline   Reply With Quote
Old   May 31, 2012, 15:49
Sure. I use Eulerian multiphase model. You can see the detail in the picture. The problem is after only 27 steps, the troubleshooting error happens. I tried to change initial conditions more physically reasonable. But the error still happened.
The basic geometry is shown too. Upper part is porous region and lower part is fluid region.
I really appreciate if somebody can give some suggestions!
Old   May 31, 2012, 15:50
Default Pictures for model and geometry
Please see the attachment.
Difference of multicomponent and multiphase homogenous flows Luk_Fiz CFX 11 April 4, 2013 05:29
Use data from multiphase into DO radiation yashmash FLUENT 0 October 7, 2011 03:57
multiphase multicomponent physics ckleanth CFX 3 June 4, 2009 20:15
Species Transport with Multiphase flow in FBR venkat FLUENT 1 July 23, 2008 23:53
Multiphase flow modeling Paul CFX 2 August 11, 2003 09:41
