Morpher Problem
Old   June 1, 2012, 16:33
Default Morpher Problem
Henry Arrigo
Henry Arrigo is on a distinguished road
Hello all;
I use rigid body morpher to enforce a cylinder to move in a sinusoidal manner. but the problem is that although the equation has the amplitude of 0.02, the cylinder move more than this value (even more that 0.1). is there any extra setting that I should do? Do I skip something? I don t know what the difference between "Displacement" and "Rigid Body" options in morpher model.
tnx
Henry Arrigo is offline   Reply With Quote
Old   June 1, 2012, 17:03
bryan he is on a distinguished road
If your displacement function is correct, then I think the problem is the set up of " Total displacement" property.
When ticked, "The specified displacement will be treated as a total value relative to the initial position at time zero."
When it is cleared,"The specified displacement will be applied to the vertices based on their position at the start of each time step."
You can check detail in userguide.
bryan he is offline   Reply With Quote
Old   June 7, 2012, 08:11
Henry Arrigo
Thank you bryan; I ticked “Morph From Zero” option but I still have the problem. Here is what I did for the morpher option: I defined a function as “0.02*sin(omega*$Time)” then in the “physics condition” menu of the Cylinder I changed the “morpher method” from “fixed” to “rigid body”. I left all the “physics condition” of the Cylinder unchanged except for the “Linear displacement”. I changed the mode of this option from “constant” to “composite” and assign the above sinusoidal function to the z (vertical) component. Is that correct?
Old   June 9, 2012, 13:43
Henry Arrigo
No one knows?
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
