-   STAR-CCM+ (http://www.cfd-online.com/Forums/star-ccm/)
-   -   Nusselt Number (http://www.cfd-online.com/Forums/star-ccm/102900-nusselt-number.html)
fisicas1 June 5, 2012 20:40
Nusselt Number
3 Attachment(s)
I have a pipe with heat flux outside, I have a line of point inside the pipe with a fluid, I should have the temperature the pressure and de Nusselt Number, but for temperature and pressure I have normal result but in the case of Nusselt Number my values are always 0. anyone know what is happening? we can see the pictures.
Ladnam June 10, 2012 14:52
For the Nusselt number field function you need to specify reference length, temperature and thermal conductivity.
fisicas1 June 10, 2012 16:56
1 Attachment(s)
I used this values in the referent and the position is ok, because I have normal pressure and temperate in my point line
Ladnam June 11, 2012 00:38
Ok, are you using the pipe surface as input to the line plot?
fisicas1 June 12, 2012 09:04
I was not using the pipe surface as input, I was using the fluid! :o
thanks!!!!
