DFBI residuals and Initial conditions!
Old   June 25, 2012, 05:19
Default DFBI residuals and Initial conditions!
muhsin
muhsin is on a distinguished road
Hi All
I am working with VOF waves and dfbi with waves in +ve Z direction and rotation of body in X direction only.
I have chosen proper time step ( implicit unsteady) and number of iterations.
1. Residuals after every timestep seems to be jumping too high especially X and Y momentum and that of Water. Is there anything that can be done?
2. Reverse flow at pressure outlet though my pressure outlet is far off.
3. Do I need to calculate turbulent properties for initialisation or use default values?
I am using Overset mesh for this purpose...
Thanks
Regards,
Muhsin
muhsin is offline   Reply With Quote
Old   July 6, 2012, 18:40
abdul099 is on a distinguished road
What does "residuals jump TOO HIGH after every time step" mean? What is too high?
It is nothing special that residuals are jumping up after a time step. And it's no issue as long as they drop in the next time step.
Usually reversed flow doesn't harm. You've got a movement of your 6DOF body, pushing fluid out of your domain. Therefore some fluid needs to re-enter the domain. And fluid entering the domain through a pressure OUTLET is ending in the "reversed flow" message. That's all.
We do three types of jobs here:
GOOD, FAST AND CHEAP
You may choose any two!
abdul099 is offline   Reply With Quote
Old   July 6, 2012, 21:29
muhsin
Thanks for your reply sir,
Jumping to to the values of say 5-10. my Sdr and Tke residuals converge well near or below .001, rest all fine.
But when i change time step discretisation to second order my Sdr and Tke residual are too high say 100-500 and dont converge to next time step, but the run goes on.
Also, when i change Turbulent specification to K+omega, free surface distorts and solution diverges soon after that.
Old   July 14, 2012, 03:45
Don't worry about the level of the residuals since they are normalized in ccm+. It's just also nothing special that the residuals jump up every time step, it's just important that they drop again during the time step.
For your second issue, I don't have an idea without having more information about your setup. But I would check the usual suspects: Time step, mesh resolution and of course, did you specify proper values for k and omega...
Old   July 14, 2012, 05:37
muhsin
thanks! 1. so i need not to worry about residuals if they converge well every timestep.
2. i can send you my .sim file if u say... time step is .01s for a max velocity of .3m/s and min cell thickess of .005m.
i used both default values and calculated values of K and omega for my set up.
for calculation i used the formulation from fluent manual.
Old   July 16, 2012, 17:09
The k-omega model is very sensitive to your turbulence specification. I would enter the values for turbulence intensity and turbulent viscosity ratio. Then Star-CCM+ will calculate proper values for k and omega.
Anyway, when the default values don't work, I would check for a proper mesh resolution. Maybe you can post a picture of a section through your domain...
Old   July 17, 2012, 00:05
muhsin
I am posting picture of my domain. origin is at the base of the body. domain extends from -6m to 20m.
plot residuals in multiregion solver val46 OpenFOAM 4 December 12, 2016 06:06
How to get initial residuals for U components during runtime? florian_krause OpenFOAM 3 May 6, 2011 08:54
Definitions for Initial and Final Residuals will_avoid_comm_solvers OpenFOAM 1 July 16, 2010 03:55
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 00:36
