Need help to simulate R22 Evaporation-Condensation Simulation... |
June 29, 2012, 00:48 |
Niaz Ali Ahmed
Hello everyone. I am using Star-CCM+ v 7.02.011 for simulating Condenser of a Refrigration Unit.
Problem Statement : Make superheated R22 Gas enter the pipe (10m length and .00615m diameter) and observe a drop of 8C temperature drop along with phase change from R22 Gas to R22 Fluid Inputs Used : Material Used : I have created a custom .mdb( Material Database File ), containing density and specific heat as polynomial data from REFPROP Database for both R22 Gas and R22 Liquid. Boundary Condition : Negative Heat Flux applied at wall of pipe to make the fluid loose the enthalpy. Using corelation it is around 6.4W spread at a surface area of approximately 0.19m2. Model for Evaporation/Condensation: VOF Phase Interaction Model along with Evaporation/Condensation model. Simulation The simulation runs and converges easily and residuals show no wiggles and converges easily. Problem Faced The phase change doesnt happen, and the temperature remains constant throughout the domain. I have gradually tried to apply more negative heat flux at the walls, but no luck. Note : I have checked the Solver Frozen node in energy equation but the solver is enabled. Still have trouble making the termperature drop in fluid. "Please help me in solving the temperature drop and phase change problem." |
July 16, 2012, 08:37 |
Aga
Can you use the model of Vof with evaporation and condersation at ver.7.02?
July 16, 2012, 08:48 |
Ryne Whitehill
Rep Power: 18 |
Don't think this will solve the problem at hand, but make sure your properties transferred up from your material. I.e. go up to your Physics Continua, expand Models, expand Gas, and then your entry. Make sure the specific heat is set to same values you set below. I was having this issue recently
July 16, 2012, 10:04 |
Aga
I try to use this model, but disaply error message.
The message is ConditionManager: get(T): condition not found: class peciesSpecification. Who could help me to solve this problem? |
July 24, 2012, 01:00 |
Niaz Ali Ahmed
@rwryne
I have noticed that problem here too. I have been doing a lot of work since I posted my query. I have defined two R22 phases now. Density is now entered as a field function expressed as a function of Pressure and Temperature. Specific Heat as Polynomial in T. Saturation Pressure also as a Polynomial in T. Enthalpy is set to specific heat method. Sorted : Density is as indicated in p-h diagram Enthalpy is also accurate. To be sorted : Single phase simulation runs fine, but multiphase problem show divide by zero. Its probably due to some junk data or curve overlap of some field function. @Icweng : Yeah Evaporation-Condensation is available in 7.02.xxx "ConditionManager: get(T): condition not found: class peciesSpecification" Check whether the multiphase physics node has the Energy model selected. Sometimes I get this error. Only way to sort it out is start a fresh simulation. |
June 24, 2013, 01:39 |
Kevin Wang
Rep Power: 12 |
Hi, niaz.
I've tried to simulate water vapor condensation outside a tube through CCM+7.02. After I setted the parameters in Evaporation and Condensation model, and run the simulation, an error occured: SaturationPressure::getMaterialProperty(): property missing Have you faced with a problem like this? Do you know what's the reason? Waiting for your response. Thank you in advance! |
August 24, 2016, 14:55 |
Evaporation simulation of R404A
stalukar
Rep Power: 9 |
hello... I am trying to develop a simulation model for evaporation of refrigerant in evaporator tube to find the best feasible tube length of tube. I am using fluent 14.5 and mixture model of multiphase flow. I am facing some major problems. 1. where should I start computation (inlet or hot wall)? 2. A message contains 'reversed flow on 50 faces in pressure outlet' are being shown at the begining of calculation. Could you please help me how I can solve this? I am feeling very much helpless......................E
Rigid body motion error when restarting a terminated FSI simulation | lingdeer | ANSYS | 1 | May 19, 2013 01:40 |
simulation of heat pipe (evaporation part) | DanielLai | FLUENT | 0 | November 5, 2011 10:26 |
numerical simulation about condensation | Sam Liu | Main CFD Forum | 0 | November 1, 2004 20:41 |
Condensation simulation? | Gregor Kotnik | Main CFD Forum | 4 | May 2, 2000 16:13 |
3-D Contaminant Dispersal Simulation | Apple L S Chan | Main CFD Forum | 1 | December 23, 1998 10:06 |
