Home > Forums > STAR-CCM+
undstaedy boundary
Like Tree2Likes
  • 1 Post By abdul099
Old   July 16, 2012, 07:15
Default undstaedy boundary
hayder
hyderkhan74 is on a distinguished road
I Make simulation for the wind flow above house and to show the effect of changing winds direction with time ,for this purpose it need to continuous change of the boundary (e.g. inlet to outlet) with time. So I will be grateful to any one show me a way to do this with star ccm+ .
hyderkhan74 is offline   Reply With Quote
Old   July 16, 2012, 16:51
abdul099 is on a distinguished road
To change the boundary type is only possible by using a Java macro. But I think, you don't need to change the boundary type, but just change the condition (e.g. inlet velocity). When the inlet velocity changes with time, you will have the same effect. You just need to make sure, your fluid is SLIGHTLY compressible and your geometry allows this change.
hyderkhan74 likes this.
We do three types of jobs here:
GOOD, FAST AND CHEAP
You may choose any two!
abdul099 is offline   Reply With Quote
Old   July 18, 2012, 05:17
hayder
Dear Abdul thank you for your help ,but can you explain what you mean by (SLIGHTLY compressible and your geometry allows this change) ?
With regards
Old   July 28, 2012, 05:23
When your domain is cylindrical (vertical axis) and the house resides in the center, you can set the total lateral surface to be a velocity inlet with a specified flow direction. This will allow an easy change of the flow direction just by changing the direction, but you don't need to touch the boundary type.
This is not possible when you have a box-shaped domain, that's what I mean with "your geometry allows this".
But in this case, you would have only one boundary with a fixed volume flow rate at every face of the boundary. Therefore the solver will struggle to get the continuity equation to converge due to rounding errors, cpu accuracy etc.. Therefore it's best to set the fluid to be slightly compressible, so the solver has an additional degree of freedom to reduce the mass imbalance without violating the volume flow rate of the boundary condition.
Old   July 28, 2012, 05:27
hayder
It`s clear now ,thank you
Thread Tools
Trackbacks are On
Implementation of boundary conditions for FVM Tom Main CFD Forum 7 August 26, 2014 05:58
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
CFX doesn't continue calculation... mactech001 CFX 6 November 15, 2009 22:25
Boundary conditions? Tom Main CFD Forum 0 November 5, 2002 02:54
Boundary Conditions Jan Ramboer Main CFD Forum 11 August 16, 1999 08:59
