Error: Cycle detected in field function
Like Tree1Likes
  • 1 Post By abdul099
Old   July 19, 2012, 06:15
Default Error: Cycle detected in field function
Rachit Prasad
Rachit is on a distinguished road
Hi everyone,
I am carrying out a CFD analysis of a wind turbine. I want the turbine blades to rotating. The idea is to define a circular region around the blade which will be rotating at a certain angular velocity and will exchange data with the surrounding environment through a sliding mesh. Now, what I want is that angular velocity of the circular region be defined as:
w = 2.3559, for t <= 0.015s
w(t) = w(t - 1) + (Torque / Moment of Inertia)*TimeStep, for t > 0.015s
where Torque is the moment on the turbine blades.
for this i had defined a field function UserFieldFunction_1 defined as:
($Time <= 0.015) ? 2.3559 : $UserFieldFunction_1 + (($Torque/1.308)*0.005)
(moment of inertia is 1.308 kgm^2 and the time step is 0.005s)
however, following this i get the error message: "Warning: 1 cycle detected in function Turbine anglular velocity (UserFieldFunction_1)"
can anyone what am i doing wrong and how it can be rectified? i think its because of referencing the same field function in code, but then how else could such a function be defined?
Thanks in advance,
Regards,
Rachit
Rachit is offline   Reply With Quote
Old   July 19, 2012, 10:19
Ryan Coe
ryancoe is on a distinguished road
If understand the logic that you're trying to use correctly, couldn't you use:
($Time <= 0.015) ? 2.3559 : 2.3559 + (($Torque/1.308)*0.005)
In your current implementation, when t > 0.015 the algorithm can never find a value of $UserFieldFunction_1 to use in the 2nd half of the statement.
Hope this helps,
Ryan
Ryan
ryancoe is offline   Reply With Quote
Old   July 24, 2012, 04:48
Rachit Prasad
Hi Ryan,
Thanks for replying. I shall be more clear of what I wish to accomplish, and correct me if I am wrong. I want the turbine to rotate with an angular velocity which is directly obtained from the equation:
Torque = I*alpha, where I is moment of inertia and alpha is the angular acceleration
that gives, alpha = Torque/I
now applying, euler's first order integration, we have
[(w(t) - w(t - 1))/delta T] = Torque/I
that gives me the relation mentioned in the previous post:
w(t) = w(t -1) + (Torque/I)*TimeStep
that is why I have to use the angular velocity from the previous time step. I understand what error I am getting, any idea how I can bypass it?
Regards,
Rachit
Old   July 24, 2012, 08:26
Ryan Coe
I see... Sorry I misunderstood you before. I think that the easiest way to do this within Star-CCM+ (that is without using macros), would be to assign the value of w(t) to a table value, and then reference that value as well. I've never done this myself, but I'm pretty sure its possible (there's a section describing this sort of thing in the Help manual: "Working With Table Values Through Field Functions").
Alternatively, if you want to stay away from tables and just use an algorithm, you could write a java macro containing a for loop which creates and references the array w(t). The macro can then reassign the new w(t) value to a field function at every time step.
Ryan
Ryan
Old   July 27, 2012, 04:20
Rachit Prasad
Dear Ryan,
I have been trying to figure out how to write a macro for this situation only to find myself extremely confused . This is my first macro so correct me if my approach is wrong. What I have been thinking is that I could record a macro in which I will change the field function definition as: [(2.3559 + (($Torque/1.308)*0.005))], following which I will run the simulation for 1 time step.
On recording this macro, I will change its java script by defining a variable temp which initially I will set it as 2.3559 and change the user field function definition as: [(temp + (($Torque/1.308)*0.005))], however, the value of temp has to be updated after every time step as temp = UserFieldFunction_1. I can then run the simulation for as many number of time steps by modifying simulation_0.getSimulationIterator().run().
Could you tell if this is possible or not? I have recorded the macro, but have little idea how to modify the java script. How can i update the term temp after every time step? Are there any guides available for scripting in Star CCM+? (There are very less examples in User Guide)
Old   July 27, 2012, 11:19
Ryan Coe
If you've done any programming, editing and writing macros shouldn't be too hard. I would definitely suggest using an IDE like Netbeans or Eclipse. If you point theseIDEs to Star-CCM+'s packages, they can be really helpful.
There are 2 tutorials on Automation in the Help Manual that should give you a basic understanding of how things work.
I know this can be a bit daunting at first, but its worth your time.
Ryan
Ryan
Old   July 28, 2012, 08:36
abdul099 is on a distinguished road
You don't even need to update the field function, you can try it with the attached macro. I couldn't upload a java file, so I renamed it to txt. Just change the file ending to java, and you can execute it in Star-CCM+.
I haven't tested the macro, but just try it and let us know when it doesn't work.
bluebase likes this.
We do three types of jobs here:
GOOD, FAST AND CHEAP
You may choose any two!
abdul099 is offline   Reply With Quote
Old   July 30, 2012, 06:42
Rachit Prasad
@abdul099
Thanks a lot! Your macro works just fine. I am getting the expected results.
Regards,
Rachit
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 04:49
Field Function Question. Need help writing it :((( kj878 Siemens 1 February 14, 2012 18:30
LiencubiclowRemodel nzy102 OpenFOAM Bugs 14 January 10, 2012 08:53
Force Report help~ or maybe Custom Field Function sailor FLUENT 0 April 13, 2011 03:45
time step size in Custom Field Function Tong FLUENT 0 May 2, 2008 15:51
