in-place interface problem
Old   August 16, 2012, 11:14
Default in-place interface problem
ajay.mighty@gmail.com
ajay.mighty is on a distinguished road
I used in-place interface between the porous region and fluid region for my problem. I even initialized the interfaces. But there is no connectivity between the slave and the master faces.
could any one tell me the reason?
ajay.mighty is offline   Reply With Quote
Old   August 16, 2012, 15:33
eRzBeNgEl is on a distinguished road
Just a guess, maybe imprint the interfaces and try it again! If there is no gap between these interfaces there should be a connection
eRzBeNgEl is offline   Reply With Quote
Old   September 9, 2012, 12:05
Zeppo's Avatar
Sergei
Zeppo will become famous soon enough
You can check an interface by eye. As you pick it in the model tree the faces are highlighted with a color so that you could see if they are right or not. Besides, check a tolerance value within your interface.
Zeppo is offline   Reply With Quote
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Problem with interface Roland R CFX 6 March 1, 2018 08:24
problem with interface in heat conduction josefguerreroj ANSYS 1 June 8, 2013 20:19
Problem with interface in a wind turbine simulation be_inspired FLUENT 2 March 7, 2011 23:46
Interface problem Tomislav FLUENT 4 May 23, 2006 00:49
