turbine RPM in star-ccm+
Like Tree1Likes
  • 1 Post By abdul099
Old   August 11, 2012, 03:28
Post turbine RPM in star-ccm+
saleh
saleh alsubari is on a distinguished road
Dear friends
i have problem to find the RPM of the turbine blades given that the mass flow rate.means that ,the RPM must be output ...is there any one can help
thanx in advance
saleh alsubari is offline   Reply With Quote
Old   August 28, 2012, 19:10
abdul099 is on a distinguished road
You'll find the answer in several posts you've already answered to ask for an explanation.
I'm in a good mood, so I'm doing the work to type a short version of the explanations of 5 other posts:
Set your case up (mesh, physics etc.), run with a more or less arbitrary rpm and compare the torque generated by the turbine with your load torque. Adjust the rpm, run, compare again etc.
Repeat this until your output torque equals the load.
When you need more information, PLEASE don't just ask for information, PLEASE READ the posts you've already found. It's all explained there and should answer most of your questions.
saleh alsubari likes this.
We do three types of jobs here:
GOOD, FAST AND CHEAP
You may choose any two!
abdul099 is offline   Reply With Quote
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
Fluent Vs Star CCM firda Main CFD Forum 3 February 26, 2011 02:51
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
error in star ccm maurizio Siemens 3 October 16, 2007 05:17
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
