Using multiple cores
Old   October 4, 2012, 19:41
Default Using multiple cores
tsmith10 is on a distinguished road
I am pretty new at using STAR-CCM+ and noticed while running a simulation that only one of my four cores was being used. Is this a license issue? I tried running the simulation using the parallel option but it gave me errors and wouldn't run. Am I doing something wrong or is there a different type of license needed to run the program on multiple cores? I appreciate any help!
Thanks
tsmith10 is offline   Reply With Quote
Old   October 4, 2012, 22:00
KHB
lava12005 is on a distinguished road
You can check how many license that you have using the lmtools (or maybe other people is using it?)
If you have enough license and still cannot run it in parallel, then easiest is to contact CD-Adapco support directly.
lava12005 is offline   Reply With Quote
Old   October 5, 2012, 04:09
siara817's Avatar
siamak rahimi ardkapan
siara817 is on a distinguished road
It depends on the license type. Some licenses can be used to run on up to 16 processors. maybe your license is for just one processor ( however that is weird).
siara817 is offline   Reply With Quote
Old   October 5, 2012, 09:41
Ryne Whitehill
rwryne is on a distinguished road
With STAR-CCM+, there are two types of licenses:
1) Standard... this will let you do all the pre+post processing (including meshing) and run the simulation on 1 core
2) Power session.... this will let you do all of teh above but on unlimited cores.
If you have a power session, you need to check the "Powe session" box when opening your simulation
rwryne is offline   Reply With Quote
Old   October 8, 2012, 15:01
abdul099 is on a distinguished road
Additional to rwryne's post:
For every simulation, you need either ONE CCMP suite license or a power session license.
The CCMP suite license can also be used to run on additional cores when you have more than one CCMP suite available.
And there's also a cheap HPC license available, which can only be used to run additional cores together with one CCMP suite.
We do three types of jobs here:
GOOD, FAST AND CHEAP
You may choose any two!
abdul099 is offline   Reply With Quote
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
Which is better for CFD 4 core i7-2600 or AMD 8 core FX-8150? GregShaffer Hardware 3 May 7, 2015 13:26
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Fluent parallel computing on multiple Workstations slower than one peterhess Hardware 1 May 18, 2011 08:08
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
