How to plot velocity Vs time graph at a point in a flow using starccm+
Old   November 9, 2012, 01:58
Smile How to plot velocity Vs time graph at a point in a flow using starccm+
Taryk
TQIM is on a distinguished road
I m trying to plot a graph of velocity magnitude vs time at a point in a turbulent flow over a flat plate using point probe but i m unable to get a graph. Can anyone help me in sorting out this problem.
Thanks
TQIM
TQIM is offline   Reply With Quote
Old   November 9, 2012, 15:43
Zeppo's Avatar
Sergei
Zeppo will become famous soon enough
Create an expression report.
Set your point derived part as an input part for it.
Define a report expression as sqrt($$Velocity[0]^2+$$Velocity[1]^2+$$Velocity[2]^2).
Create a monitor and a plot from your report.
Go to the monitor properties and switch the trigger from 'every iteration' to 'every time step'.
Zeppo is offline   Reply With Quote
Old   November 12, 2012, 08:19
Ryne Whitehill
rwryne is on a distinguished road
You could probably just use a sum report and only include that point.
Also, I think $$Velocity.mag() would be easier than doing the full equation.
rwryne is offline   Reply With Quote
Old   November 15, 2012, 19:26
abdul099 is on a distinguished road
Again, rwryne is right. There is a field function syntax to get the velocity magnitude, but isn't it mag($$Velocity)? At least that's what the user guide tells on page 4784.
Anyway, on an expression report, you can't choose any input parts, so it needs to be a sum, minimum or maximum report. All other reports don't make much sense.
We do three types of jobs here:
GOOD, FAST AND CHEAP
You may choose any two!
abdul099 is offline   Reply With Quote
Old   November 19, 2012, 01:18
Taryk
Thanks for your reply...I tried with the expression given by you but its giving syntax error. Could you please tell me how to rectify this error.
Old   November 19, 2012, 01:20
Taryk
Thanks Ryne for your reply but I m getting syntax error when I used the expression given by you. Could you please tell me how to rectify this error.
Old   November 19, 2012, 10:51
Reza
triple_r is on a distinguished road
Can you post the error message? I think the following post gives the correct syntax
triple_r is offline   Reply With Quote
problem in toposet Ahmed Khattab OpenFOAM Pre-Processing 27 March 3, 2023 21:12
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 09:08
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
block-structured mesh for t-junction Robert@cfd ANSYS Meshing & Geometry 20 November 11, 2011 04:59
Plot a graph of velocity & boundary condition problem wanie Fluent UDF and Scheme Programming 0 December 11, 2009 10:40
