Problem with Convergence
Old   December 8, 2012, 07:10
Default Problem with Convergence
anonymous
badger1 is on a distinguished road
I am having a problem with my Starccm simulation in that it will not converge to a final solution. the residuals are very high are the solution never seems to reach a steady state where everything is constant it just keeps moving.
I am simulating a turbine blade and I am using the following models:
gamma ReTheta
K-omega
Steady
Turbulent
2D
Coupled
All Y+ treatment
Ideal Gas
I am hoping that there is something I can do in order to make it converge and reach a solution. I have attached some pictures so that you can tell what I mean. The solution is periodic which explains a little better the scaler plot.
thanks
badger1 is offline   Reply With Quote
Old   December 11, 2012, 18:08
Smile
Luís Ferrari
luizhferrari is on a distinguished road
Oi, tente diminuir o fator de sobre-relaxamento, o default é 0.9, tente abaixar para 0.5, isto poderá deixar problemas de tempo em sua simulação, caso não, pode ser problema de modelo mesmo, tente colocar uma sonda e monitorar por isto.
gamma ReTheta
K-omega
Steady
Turbulent
2D
Coupled
All Y+ treatment
Ideal Gas
thanks
Attachment 17510
Attachment 17511
luizhferrari is offline   Reply With Quote
Old   December 13, 2012, 03:09
siara817's Avatar
siamak rahimi ardkapan
siara817 is on a distinguished road
Seems to me that the mesh is coarse. But before that try to change physics models from second order to first order. See if it gets converged or not. if yes, then change to second order after for example 2000 iterations.
Good luck
Siamak
siara817 is offline   Reply With Quote
Old   December 18, 2012, 04:54
anonymous
I tried to change both the order from 2nd to 1st and also the couant number and also the relaxation.
The simulation converges fine if you use segregated and constant density, but if you use coupled and ideal gas it does not and gives stupid results and never reaches a steady state solution.
I need to use coupled and ideal gas to match an experiment that someone else has done.
Old   December 20, 2012, 13:23
siara817's Avatar
I think if you want to try coupled, you need to reduce more the relaxatoin factor. It will take certaily longer to converge, you need to be patient.
Good luck
Siamak
convergence problem when use pisoFoam, LES for wind tunnel case Forrest_Lei OpenFOAM 3 July 19, 2011 06:00
convergence problem commonyue Main CFD Forum 1 December 1, 2009 03:54
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
3D Fluid Flow Convergence problem Emily FLUENT 2 March 21, 2007 22:18
Non Convergence of 3D Heat transfer cfd problem Balraj Main CFD Forum 3 December 9, 2004 00:24
