December 21, 2012, 12:58 |
Floating point error with Solar radiation
Ruzic
Rep Power: 14 |
Hello
I made model (single region, air) with solar radiation through couple of transparent walls. The same model works fine without grey radiation, with grey s2s radiation, but when activate solar radiation, following error message appear after >>Viewfactors solver: finished. CPU Time: 216.27, Wall Time: 216.27, Memory: 519.88 MB Turbulent viscosity limited in 563 cells in region Region 1<< "Server error: A floating point exception has occured... The specific cause cannot be identified..." I ran simpler models with solar radiation and the same boundary caonditions and they worked ok, so I'm not sure where is the difference and therefore cause of error, except in shape, size and number of cells... Thanks Ruzic |
December 21, 2012, 14:38 |
Ruzic
Rep Power: 14 |
Problem solved: azimuth angle was set to zero (default value), but this is obviously not supported
Changed to 1 deg - iteration started normally Last edited by Ruzic; December 22, 2012 at 05:06. |
floating point exception, solar |
Display Modes | |
No convergence; floating point exception all the time | Tobi | OpenFOAM | 2 | September 19, 2012 04:01 |
solar radiation | greg | FLUENT | 2 | August 18, 2006 05:08 |
solar radiation | Arnold | FLUENT | 0 | May 2, 2006 21:00 |
solar radiation | su nam | Siemens | 0 | July 30, 2004 02:17 |
solar radiation | raymond | Siemens | 2 | February 3, 2002 22:14 |
