interpolating data as a function of position
Old   December 21, 2012, 08:24
Default interpolating data as a function of position
tao
sydrna is on a distinguished road
hallo does anyone know how to set a new field function to compare 2 scalar data of temperature of a plan section by using interpolatetables?
sydrna is offline   Reply With Quote
Old   December 24, 2012, 06:13
anonymous
badger1 is on a distinguished road
what do you mean by compare two temperature values using interpolate tables?
badger1 is offline   Reply With Quote
Old   December 25, 2012, 04:50
tao
i just want to do the mesh independence. i have two mesh variant and export one scalar table that represent temperature of a plan section from one variant. and then import to the other using tools-tables. after that by field function i set a new one with the befehl interpolatepositiontable(scalar). finally id like to compare the new scalar and the scalar function in the 2nd mesh variant of the same plansection in 1st mesh variant. do i need a new field function in that the two scalar function of temperature substract each other so that i can clearly see that the difference(%) of temperature between two mesh variant. there are realy litte information in user Guider. i just look for help. thks
Old   January 5, 2013, 17:41
abdul099 is on a distinguished road
Both works, you can do it in one field function or in a separate one. I recommend to do the subtract in a separate field function.
Reference it by something like
$Temperature-$InterpolatedTemperature
depending on the name of your position interpolated temperature field function.
We do three types of jobs here:
GOOD, FAST AND CHEAP
You may choose any two!
abdul099 is offline   Reply With Quote
Access particle data in main function moritzhoefert OpenFOAM Programming & Development 2 September 15, 2017 10:31
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
Interpolating volume data onto quad surface mesh N.R. CFX 6 June 7, 2007 08:15
