January 8, 2013, 11:26 |
2D Velocity Inlet
Hi Everyone,
I'm currently working on a simulation of a plate where I would like to compare my results to the results of the blasius equation. Therefore I choose a specific point of the plate in x-direction (e.g. x=1,5m) where I set a calculated velocity profile to give the flow an initial speed. This profile is calculated using matlab and consist of u (flow in x-direction) and v (flow in y-direction). My problem is now, that by selecting "table(x,y,z)" at the velocity inlet boundary I can only set one flow direction (u or v), but my initial flow consists of both u and v-values. Can anyone help me please? Thanks a lot! |
January 10, 2013, 14:44 |
Rep Power: 21 |
You can switch the input method to components and put a table(x,y,z) for every velocity component.
We do three types of jobs here: GOOD, FAST AND CHEAP You may choose any two! |
blasius, blasius flow, inlet, profile, velocity |
Display Modes | |
Velocity Inlet BC -- Flow Reversal | salihovic | FLUENT | 0 | May 8, 2011 05:45 |
Changing Boundary: Decreasing Inlet Velocity - Convergence Issues | VT_Bromley | FLUENT | 3 | February 12, 2011 09:02 |
User Defined Profiles, Swirl, Velocity Inlet | saurus | FLUENT | 0 | January 26, 2011 15:35 |
Unexpected difference between velocity / mass-flow inlet | jpo | FLUENT | 8 | December 10, 2010 07:20 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
