airflow in room
Like Tree1Likes
  • 1 Post By abdul099
Old   January 15, 2013, 08:16
Question airflow in room
Shane Farrell
shanefarrell is on a distinguished road
Im relatively new to star ccm and i am trying to produce a simple simulation of the airflow patterns in a clean room. The model is basically a box with 9 inlets on the roof and 3 outlets at the base of two of the side walls. The flow is run as a steady incompressible laminer model. The inlets are set as velocity inlets with a velocity of 0.5 m/s. I have set the outlets as both pressure outlets and split flow outlets for seperate simultions, but when i tried to solutionize them, they wouldnt converge and im getting oscillating residuals. Can someone please tell me where im going wrong or am i not inputing enough data for the simulation to work? Thanks in advance.
shanefarrell is offline   Reply With Quote
Old   January 15, 2013, 16:16
abdul099 is on a distinguished road
How do you judge convergence? Oscillating residuals are more or less normal when you're running a steady simulation since most flows are not really steady.
jjanakpatell likes this.
We do three types of jobs here:
GOOD, FAST AND CHEAP
You may choose any two!
abdul099 is offline   Reply With Quote
Old   January 16, 2013, 02:26
siara817's Avatar
siamak rahimi ardkapan
siara817 is on a distinguished road
Hi
I think the problem is that you have considered a turbulent case as laminar, the case is turbulent I think. As the velocity is low, you need to activate a near wall treatment model, the best is to use Two layer all y+ wall treatment.
run the simulation first by running first order scheme and then if it is converged change it to the second order.
Good luck
Siamak
siara817 is offline   Reply With Quote
Old   January 18, 2013, 15:04
I don't think this is the issue. Even when you run a turbulent case, you can often experience oscillating solutions. There's a difference between a turbulent case (which models small scale unsteady turbulence effects) and a laminar unsteady case (which models unsteady effects, but does not take small scale turbulence effects into account).
This does not necessarily depend on the velocity. Also a two layer model has it's restrictions, and pretty often you mix crap with crap by using a two layer model without properly adjusting your mesh to this model. It is dangerous to use a two layer model as a general advice when the one using this model does not now where the limitations are.
When a simple case like this is set up in a proper way, you should not need to run first order before switching to second order. Your flow might not show the unsteady behaviour when running first order since it smears the solution. But when you switch back to second order, it's just a matter of time until you can see the unsteady behaviour again. So this does not help to get a non-oscillating solution. It helps only when you case diverges during the first few iterations.
I think shanefarrell needs to give some additional information to judge what the issue is.
flow split, pressure outlet
Modelling airflow distribution in a room gangstagan FLUENT 1 January 21, 2011 12:51
room airflow simulation jayarvacs Main CFD Forum 0 March 10, 2010 21:01
airflow modelling in a room shahriel FLUENT 3 September 4, 2008 10:34
modeling objects in room airflow ahmet FLUENT 2 February 21, 2007 20:41
large room airflow - what approach?>> lincl Main CFD Forum 2 September 25, 2003 13:21
