-   STAR-CCM+ (http://www.cfd-online.com/Forums/star-ccm/)
-   -   College Assignment - 2D Airfoil Low Re (http://www.cfd-online.com/Forums/star-ccm/111791-college-assignment-2d-airfoil-low-re.html)
brophya2013 January 15, 2013 12:49
Hi All,
I am trying to model a 2D Airfoil in Star-CCM+ with little success. The Airfoil is a NACA0025 that was created in ProEngineer Creo and save as a .x_t file.
When I create the structured mesh and convert to 2D, the mesh is coming out as "botchy" around the airfoil. It does not look as good as mesh from GridPro but we can not use this.
I imported the airfoil and created a block around the airfoil to simulate the wind tunnel. The surface size of the airfoil is smaller than the surface size of the wind tunnel.
Is there something that I am missing, the Cl values are double what I am expecting.
Thanks for reading,
Andrew
abdul099 January 15, 2013 17:12
How do you create a structured mesh? Or do you mean a trimmed mesh? Can you please post some pictures of the mesh?
brophya2013 January 16, 2013 06:58
2 Attachment(s)
Thanks abdul for your reply,
Yes, by structured mesh I mean trimmer, apologies for not being clear.
See attached pics.
Andrew
abdul099 January 18, 2013 16:12
Sorry when I'm a little direct, but your prism layers are... crap.
First, make sure your last prism layer is not thicker than the first trimmed mesh cell. The transition from the prism layers to the bulk mesh is pretty important. Maybe you also need to increase the growth rate a bit.
I also would add an at least small trimmer wake refinement to capture flow details of the air leaving the airfoil. And make sure, the prism layers at the trailing edge are not so thick, they will not be so important there.
And when the first picture should be your whole domain: That's too small. There will be a pressure and velocity field around the airfoil which should NOT be affected by the boundary conditions, which are usually a fixed velocity or something similar. In general, the airfoil should be far enough from the boundary, that the velocity field (e.g. a slower velocity in the stagnation point) does not reach to the boundary condition. So make sure, your box around the airfoil is far enough to not affect he airfoil. This might be a bit hard since you might need huge domain, but you can have pretty big cells far away from the airfoil. Even when it's more than 20 times the airfoil chord length: That's nothing special.
Please try to improve the points I've mentioned, and keep us informed about the success.
brophya2013 January 21, 2013 15:44
3 Attachment(s)
Thanks abdul for the reply and appreciate the bluntness. I'm a new user and first time using this software.
Attached is my updated mesh - now I have four blocks as volumetric controls and I've added a wake refinement and made the inlet 30 times the chord lenth away and also the outlet.
For 10 deg AOA I expect Cl to be 1.0, im getting in the region of 1.5-1.6. The Re is approximately 270000.
All feedback welcome.
brophya2013 January 21, 2013 15:45
2 Attachment(s)
Two more attachments.
Andrew
brophya2013 January 28, 2013 04:44
Any ideas about my mesh please?
