Home > Forums > STAR-CCM+
Leakage in star ccm+
Old   January 19, 2013, 00:13
Default Leakage in star ccm+
Suyash Patkar
Suyash26 is on a distinguished road
How is it possible to simulate room with open window? That is I want to consider the air leakage through the window.
Suyash26 is offline   Reply With Quote
Old   January 19, 2013, 10:05
MM
mk_mard is on a distinguished road
I suppose you should use the 'buoyancy feature' and simulate air inside and outside the room.
mk_mard is offline   Reply With Quote
Old   January 21, 2013, 05:48
siara817's Avatar
siamak rahimi ardkapan
siara817 is on a distinguished road
If you want to simulate the natural flow from the room through an open window, then it means that you have an over pressure inside.
The reason could be stack effect or wind effect.
For any case you need to define an inlet where the fresh air comes into the room. Then you will put your window as flow split outlet.
Good luck
Siamak
siara817 is offline   Reply With Quote
Thread Tools
Trackbacks are On
Using starToFoam clo OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 33 September 26, 2012 04:04
Problem In Star CCM Plus ramarya STAR-CCM+ 1 July 10, 2011 05:59
StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
error in star ccm maurizio CD-adapco 3 October 16, 2007 05:17
Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 2 July 15, 2005 04:15
