Line Probe Smoothing
Old   February 16, 2013, 07:42
Default Line Probe Smoothing
anonymous
badger1 is on a distinguished road
I am having some trouble with the line probe function in Starccm+ and creating a plot from it.
I have a turbine blade and on the surface is a line probe starting at the surface and on a vector normal to the surface (shown in the image) 2D_NFC_1f_Mesh Scene 1.png
I am then looking to assess the velocity profile in this region so I have created a plot.
As you can see the plot is not very smooth as some of the cells have a number of line probe points in them and others near the surface have only one.
I have used the smoothing function as shown below but there are still issues (at the corner for example at a velocity of 14m/s) so I was wondering if anyone knew of a way to sort this.
I really just want to create a line probe or something and when extracting data only take the value in each cell once and associate that value with the centre of the cell for example not multiple times at different locations in the cell.
thanks
badger1 is offline   Reply With Quote
Old   May 21, 2013, 22:36
Abdullah Karimi
abdullahkarimi is on a distinguished road
Originally Posted by badger1 View Post
I have a turbine blade and on the surface is a line probe starting at the surface and on a vector normal to the surface (shown in the image) Attachment 19069
Attachment 19070
Attachment 19071
thanks
The best way would be to go to 'Resolution' of the line-probe edit and then increase it so that you will have more points. By default it is 20 points which might not be sufficient.
abdullahkarimi is offline   Reply With Quote
line probe, smoothing, steps
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
8x icoFoam speed up with Cufflink CUDA solver library kmooney OpenFOAM Running, Solving & CFD 42 November 6, 2012 11:37
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
