Simulation and Optimisation of centrifugal fan 3D to 2D
Old   January 31, 2013, 13:21
Default Simulation and Optimisation of centrifugal fan 3D to 2D
eRzBeNgEl is on a distinguished road
Hi guys,
I simulated a centrifugal fan with volute in 3D. Now I want to optimize the position of the fan in the volute regarding pressure rise...!
Therefore I created built a 2D simulation including impeller and volute. My velocity inlet is given by the velocity output of the 3D file in a specific range. (Output.csv including velocity, i,j,k, Turbulence kinetic energy, dissipation rate.
I imported the velocity file for inlet conditions in the 2D Simulation. Choosing Table,x,y,z,.....Flow Direction given by Velocityi,j,k, etc...
So far the simulation is running, but if I compare the 3D simulation in the specific plane with the 2D simulation, the range of the for example static pressure (contourplot) is in the 3D simulation around -500 to 1000 PA and in the 2D Simulation -4500 to 2000 Pa.
My setup is the following:
Mesh size ~ 800k cells
Turbulence model: k-w SST
Steady
Gas - constant density
All y+ treatmen
etc...
It is not the first simulation I have done, so I am sure that my model itself is working. Just the calculated values are not realistic.
Where is the problem?
eRzBeNgEl is offline   Reply With Quote
