January 2, 2013, 11:54 |
Rendering scene problem
Rep Power: 14 |
Hi all,
This is an issue already discussed on the forum, but yet the different proposed solutions did not work for me. While importing a geometry file from StarCD (*.ccmg), the import is ok, but when rendering the scene, starccm is freezing. I've tried the solution to uncheck the 'use database rendering' option, but it does not help. I have tried to import different geometry (volume in .ccmg, or surface with some nastran file or the tutorial starccm file), but every-time I am getting the same problem. The problem is certainly from the scene module, as when I do not ask to plot the geometry, starccm does not crash. Does anyone has some hint ow to solve this problem? Thank a lot for you help. |
February 11, 2013, 11:59 |
Rep Power: 15 |
Hi, you have still the problem? What OS are you using and what is the Ouput Star-CCM+ gives you. Please upload your log file...
imported geometry, rendering, scene, starccm |
Display Modes | |
[Other] engineFoam new mesh problem | ayhan515 | OpenFOAM Meshing & Mesh Conversion | 5 | August 10, 2015 08:45 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
