Natural Convection: Energy residual does not converge |
April 5, 2013, 15:37 |
Etienne Mullin
Hey all,
I am relatively new to CFD. I am simulating natural circulation in a small box (~6inx6inx16in tall box) with 2 heater rods placed inside along the height and gravity. The rods have 'heat source' thermal conditions; one rods is at 400W, the other at 250W. The top wall of the box has a heat source condition as well of -650W. The fluid in question is water (using a polynomial in T density because the IAFW water thing generally gave me errors with T and P out of bounds). I have run the simulation with various physics continua and solver settings and finally have a solution that appears realistic. I have also refined mesh and I don't think that is an issue. The problem is that under all of the continua and solver settings I have tried (whether turbulent/laminar or steady/unsteady) my energy residual flattens out at just over 10. The XYZ momentum residuals are 10^-5, continuity 10^-3. Under turbulent models (K-Omega) TKE is about 10 and SDR is about 0.01. My question may simply be answered by telling me that a high energy residual in a natural convection simulation in STAR CCM is normal and acceptable. Otherwise I would appreciate some opinions; I can list more simulation parameters. Thanks! |
April 10, 2013, 08:53 |
siamak rahimi ardkapan
Rep Power: 17 |
I do not think that it is normal. I think there is a problem. Are you sure that the solution is converged? check if the solution is converged
Good luck Siamak |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
