Problem with Mesh generation
Like Tree1Likes
  • 1 Post By rajeev50588
Old   February 21, 2013, 10:29
Default Problem with Mesh generation
Alexander
WildSinner is on a distinguished road
Hi everyone,
I have a problem with mesh generation.
I'm doing tutorial Control_valve.
When I get a result of Surface Remesher, I have a next picture
It is not clear why there are these lines and how to fix it.
Can you help me?
Thanks.
WildSinner is offline   Reply With Quote
Old   February 22, 2013, 02:30
siara817's Avatar
siamak rahimi ardkapan
siara817 is on a distinguished road
It seems they are imported surface mesh. Just to try, go to representations, and delet import, see if the problem will be solved.
Good luck
Siamak
siara817 is offline   Reply With Quote
Old   February 22, 2013, 09:32
Alexander
In the representation i didn't have a imported mesh.
I have found, that if i turn off Scenes->Mesh scene->Displayers->Mesh->>Expert parametres->Immediate mode
These lines disappear in a volume mesh, and partially in the Remeshed surface.
I think that it is a problem with graphic display of mesh.
How can I to check quality of the mesh?
Old   February 26, 2013, 16:43
Ganesh
ganesh_krishnan is on a distinguished road
you have to run the mesh diagnostics from the mesh menu, it generates a report you can check all the parameters then, it may be the graphics driver as i once experienced this problem, try updating your driver
ganesh_krishnan is offline   Reply With Quote
Old   February 26, 2013, 22:32
rajeev50588 is on a distinguished road
Hi everyone,
Can you help me?
Thanks.
hii wildsinner...
ders nthg to worry...u can comfortably work ur way ahead...this is due to some graphics error...its the same thing i see on my PC...but ders no problem at all...i asked the service team regarding this...they said its a graphics problem...in case u have any other PC which has a better graphics card u'll not see these lines...i have tried this...
regards
RD
WildSinner likes this.
rajeev50588 is offline   Reply With Quote
Old   February 27, 2013, 10:33
Alexander
Originally Posted by rajeev50588 View Post
hii wildsinner...
regards
RD
Thanks, you are right.
I tried on the computer with the ordinary graphic card(game) and I had a good mesh without problem.
Problem card - NVIDIA Quadro 600
[Other] engineFoam new mesh problem ayhan515 OpenFOAM Meshing & Mesh Conversion 5 August 10, 2015 08:45
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 08:52
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 08:52
Problem with mesh generation Nestor FLUENT 3 November 1, 2006 02:54
Mesh generation problem Lam FLUENT 2 December 25, 2003 12:37
