February 26, 2013, 05:53 |
Half filled tank
matthieu le friant
Hello!
I would like to fill a simple tank with water.To start, I have one inlet (velocity inlet), one outlet (pressure outlet), and I Would like to add water in a tank which is ever half filled. Do I have to use Field Function Definition or can I use a simple Volume Fraction? I tried with the tuto but I don't really understand how to use the Field Function Definition ( I am French and the English tuto can be hard to understand for me!). I hope you could help me. Thank you. |
February 27, 2013, 03:25 |
Melih Meriç
Rep Power: 15 |
May be you should look to the "Passive Scalar" chapter from User Guide you can define the initial water position by using passive scalar and then you can track the filling of the tank.
Sorry i only remembered this, i have to check tut and user guide.. but passive scalar can do it. |
How to create a tank which partially filled with fluid? | ORYON | FLUENT | 45 | August 25, 2020 13:28 |
Help with a container filled half with water | nico_9188 | STAR-CCM+ | 3 | July 10, 2011 06:26 |
partially filled tank under acceleration | Jean-Gabriel | CFX | 6 | June 9, 2009 18:29 |
partially filled fuel tank | Deniz Boyacı | FLUENT | 0 | March 9, 2009 02:03 |
injection of fuel into tank filled with fuel | mujahid | FLUENT | 1 | February 19, 2004 06:36 |
